Do your back windows not close all the way?
MarkY
Phoenix
2016 Mustang EB
My wife is having this same issue with her 2016. Where exactly do you spray this silicone lubricant? Is it where the window drops into the panel?
JohnDoe
<3 short walks to my car
stop and go city traffic
15 pp vert
Put some rubber gloves on, spray it on your finger tip, shove your finger in between the weather stripping where the glass slides in. Slide your finger along the entire length of the seal, and repeat these steps until the entire seal is lubricated good. Also put some on both sides of the top edge of the window glass when the top is down
ORRadtech
Atlanta, Georgia
I don't really like silicone in any form. On my window I used dielectric grease. As said above, put some on a fingertip and coat the rubber window track in the top. I had no need to put any on the window itself. I did this about 4 months ago and the window has worked properly since.
If that trick doesn't fix the problem then you will have to adjust the actual window alignment. There are YouTube videos on the process, it looks a bit involved but not difficult.
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
@MarkY I did it with the top partially up, so it's super easy to get to the rubber seal (it's where the top of the glass contacts the top.
MarkY
Phoenix
2016 Mustang EB
Thanks everyone for the silicone lube tips. This did the trick for my wife's window.
kliffdweller
Merrick, NY
Cliff
2015 Ecoboost Premium Convertible
Same with my '15. Have had it adjusted once under warranty, but after about 6 months it started sticking again. Silicone spray only works so good. Will have to investigate how to adjust it myself now that the warranty is out.
Did you ever find out how to adjust it? I've got the same problem on my right side and wd40 no longer works.
twbthird
St Louis MO
Tom
17 GT Premium PP convertible, Ruby Red
Also, clean the quarter windows frequently. Just a bit of dust or dirt seems to add a lot of drag.
CS19
Mid Hudson Valley, NY
Rick
2019 Mustang GT/CS
I never had a problem but, to avoid it, I sprayed 303 protectant in the rubber window channel.
EZ-GT
Eliam
Whipple charged 2019 Mustang GT Convertible
Same issue here with my 19, first time I took to the dealer 3 hours later of waiting in service, it was fine. Than 2 weeks later it started sticking again.
Went with the rubber silicone grease and it’s been ok for more than a month now.
If you put too much it will drop down, but that much is really not needed, just a light spray or dab is all.
kliffdweller
Merrick, NY
Cliff
Just a note, I had sprayed WD40 and tried lithium grease when that didn't work. I should have read more carefully and used the silicon spray the first time. It works fine with that now. Does anyone know how the dealer makes any physical adjustment? What bolt to adjust, etc.?
cbrookre
Ridgefield, WA
2015 Mustang GT Convertible 50th app
No I did not, but I don't use traditional WD-40. I started using a silicone based spray and it works much better (WD-40 tends to dry out after initial application, where silicone does not).
ORRadtech
Atlanta, Georgia
There is a physical adjustment to make. It requires some dissassembly. Here a video for the rear windows and I know there are others for the front windows too.
Personally, I chose to try the "lubes the track" method first as it was easiest. As I said above, I prefer dielectric grease to silicon. I used it on the passenger side nearly a year ago and it's still working perfectly with zero dirt accumulation.
ORRadtech
Atlanta, Georgia
Just a quick update
I'm at 3 years and 9 months since I lubed the track with dielectric grease and the windows are still working flawlessly.
