stresstest
- Apr 13, 2016
- Everett, WA
- Bill
- DIB 2016 GT Premium
So about 6 months ago I was working on a new safe and really wanted it lit well. I opted to go with 12v 5050 LED light strips found on eBay. They worked out really well as seen below. Anyway, I had a bit extra on one of the spools they come on. I know Diode Dynamics makes a pretty good replacement bulb but on its best day, doesn't really do a "great" job. It's about as good as they get but I needed more light. Like me, a lot of you carry stuff in your trunk and if its on one side or the other you'll have to rifle through it to get what your looking for if you have small bins or whatever back there.
I wanted to use the same source but didn't want to cut or tap with scotch locs, into any of the factory wiring. Then it dawned on me that I had purchased these 12-LED squares from eBay as well that had adapters that came in the baggy with them. The 194 base and d-soldering the leads from the LED panel was what I used to make this setup detachable just in case I wanted to change something. Nothing was permanent in the car. I managed to locate them and went to work.
The LED strips I had purchased were water proof. Meaning they were completely silicone enclosed and came with a peal back 3M adhesive. Perfect! I used a length long enough to go fully side to side *UPDATE* The adhesive on these isn't good enough over time. I ended up using 3M molding tape (Same stuff comes on window vents) from the local auto parts store. Just stuck the strip to it and it to the underside of the deck lid. No more issues.
http://www.autozone.com/sealants-gl...-x-5-ft-scotch-mount-molding-tape/196101_0_0/
I prepped the attachment area in the car with denatured alcohol to ensure good contact.
No direct light escapes the trunk. Unless you put your head up under the rear deck you cannot see any of the LEDs directly even if you put your nose on the top of the bumper. I think it came out pretty awesome.
eBay links for what I used
Light strip
Description: 5M/10M 3528/5050 SMD Waterproof 300 LED Strip Light Ribbon Tape Roll Christmas
Link: http://www.ebay.com/itm/5M-10M-3528...hash=item2ee8446222:m:mZNrXPozzKjwryGh0h_U3hA
Options to choose:
Color: White
Model: 5050 SMD
Length: 5M
Package Contents: Only LED Strip Light
Waterproof: Waterproof
cheaper are available. this is just what I used
12LED Lights
These are cheaper
http://www.ebay.com/itm/T10-BA9S-T4...hash=item51d09cd8b9:m:mvSBvJ6AdEyRE534uBuG5ag
Choose the 9LED option and you pay $1.05 ea or find one from a domestic seller. Basically you are just after the connectors.
The under the deck picture makes the light look 8k/10k in color but that has some to do with the DIB paint and cell phone cam. Its very white white like you see in the safe.
Hope this helps
The safe I had done:
The connectors I used:
The attachment location:
The results :
Light strip
Options to choose:
Color: White
Model: 5050 SMD
Length: 5M
12LED Lights
These are cheaper
Hope this helps
The results :
