Chris796
Ford CFO
- Apr 23, 2015
- Phoenix, AZ
- Chris
- 2016 EcoBoost
Awesome job!
Eco evap and condenser with eco steel line and gt pump with gt hoses. Read back a little and i tell u how to fit one line.Do you have working A/C as well? I'm guessing that the evaporator unit is the same regardless of engine, but that the compressor is different...also the condenser unit (behind the radiator)?...probably required the right A/C hoses, too...
Every inch of wiring was swapped with ecu and bcm. I will be putting together a list of needs soon. I was saying it might be possible to only swap engine bay harness and pcm , then reprogrAm abs,bcm and cluster but not 100% on that.So reading a while back there are you saying you swapped the Body harness (behind the dash, not rearward) to the engine bay, engine bay harness (obviously) and ECU but you possibly could have left the EBM body harness in and just done the engine bay, ECU and reprogram?
Or did you have to do the dash harness. Also as far as the reprogram this was to add your vin# to the new ECU and what else?
Do it !! Wait for my parts list coming soon .......Seriously considering doing this after the new year. Like 90%
Lololol that would be funny to see the stunned looks on there faces !!Does this void the warranty ?
I'd almost pay to see a video of you taking this to a dealer and saying you think something is wrong with your turbo.
PLEASE DO THIS!Lololol that would be funny to see the stunned looks on there faces !!
