Coyote engine oil for the track?
Wally-Bob
Pompano Beach Florida
Wally-Bob
2015 GT Prem PP 50AP
I run Pennzoil Ultra Platinum 0W-20 Full Synthetic.
Like Must_Tang alluded to, there is a lot going on with using the oil to cool things in the Coyote engine...
EFI
Masshole central
5.Br0
Don't try to outsmart the engineers that specify a particular oil weight and type.
Because those engineers had only 1 thing on their mind eg. engine reliability and absolutely 0 constraints such as fuel mileage, emissions etc. when designing the engine and oil requirements.
And those are the same engineers that specified 5w20 oil for street and 5w50 oil for track use on the same engine a few years ago.
Must_Tang
MA
Gone-2016 Mustang GT Premium
Did it occur to you that perhaps they found that 5w50 in these engines caused a problem? Are you sure that it didn't?
It's a fact that as long as internal clearances and other internal engine systems support a thinner oil, it will flow better and cool better. Do some research please.
EFI
Masshole central
5.Br0
I'm pretty sure that if Ford realized that 5w50 oil caused issues in their engines they would not only switch to a thinner oil in new cars, but would also make changes to previous requirements in 2014 and earlier cars. They wouldn't just let those continue to be run on oil that causes damage since alot of those cars are still under warranty which they will have to pay for if something broke.
So given the fact that Ford still recommends 5w50 for 2014 and earlier models makes me think that that oil is quite allright.
I know how oil works, and there's also the protection factor of the oil to consider. And another thing to consider is that oil when nearing 300* temps (which is not out of the ordinary on race course use) is no where near its rated viscosity which is taken at 212*.
So your w20 oil at 300* is a w10 or lower. That's why racers use thicker oil to compensate for the increased temps. A w30 oil at 300* is closer to w20 thickness, which according to you is what you want in this engine...
Must_Tang
MA
Ok, ok, you win! I'm putting straight 40wt in for my next track day because thicker is better.
EFI
Masshole central
5.Br0
This ain't a competition, I'm not looking to "win". It's just using common sense. There was a reason Ford rated the same engine at 5w20 for the street and then 5w50 when tracked. Since you have so much confidence in Ford engineers, how come you don't trust that research and recommendation by them? Clearly they thought that the thicker oil was better suited for that type of abuse.
And if thinner is better, why don't you just put in some 0w10 or 0w0 in there?
Must_Tang
MA
Oh yeah, then why don't you put in 1000w60000 in yours?
Good night Irene!
Wally-Bob
Wally-Bob
Hmmmm, I wonder what happens with substantially thicker oil as it exits the integrated oil cooling jets that spray the bottom of the pistons to keep their temperatures down? Most likely less spray volume thus less cooling.
On hot days at the track, when it's in the 90's, I have thickened the oil some by mixing 6 quarts of 0W20 with 2 quarts of 0W-40. By my estimate this mix approximates the 20W viscosity at normal operating temperature vs. the somewhat elevated oil temps of HPDE racing on those hot days.
Must_Tang
MA
Yes, more flow provides better cooling. Higher viscosity flows less. Viscosity does not provide better protection unless the engine is designed for it, i.e. a larger bearing journal clearance.
There is an incompressible wedge of oil in the bearing journals - a higher viscosity oil does not provide more cushion, it just flows less thus cools less.
Main Bearing oil clearance on our 5.0 is 0.0009-0.0019. That is pretty tight, so you want an oil that flows through there quickly to keep things cool.
EFI
Masshole central
5.Br0
You still don't seem to grasp the concept that oil changes viscosity with temperature. All your examples revolve around a static temperature viscosity never exceeding 200*.
Yes the bearings and clearances were designed for w20 oil viscosity. Noone is debating that. But that w20 oil does not maintain the same viscosity at 250* compared to 200*...so when running at the track and experiencing higher than normal oil temperatures the stock oil viscosity is no longer relevant.
That's why people put in thicker oil, because a w30 oil at 250* is the same viscosity as a w20 oil at 200*...which is what the engine calls for. So you should not be looking at oils based on their wXX rating, you should be looking at oils that maintain the proper viscosity at the operating temperatures at which the engine is going to be experiencing.
Must_Tang
MA
From 540Ratblog. Enjoy.
SECTION 2 – MOTOR OIL VISCOSITY SELECTION
THE BENEFITS OF USING THINNER OIL:
• Thinner oil flows quicker at cold start-up to begin lubricating critical engine components much more quickly than thicker oil can. Most engine wear takes place during cold start-up before oil flow can reach all the components. So, quicker flowing thinner oil will help reduce start-up engine wear, which is actually reducing wear overall.
• The more free flowing thinner oil at cold start-up, is also much less likely to cause the oil filter bypass to open up, compared to thicker oil. Of course if the bypass opened up, that would allow unfiltered oil to be pumped through the engine. The colder the ambient temperature, and the more rpm used when the engine is cold, the more important this becomes.
• Thinner oil also flows more at normal operating temperatures. And oil FLOW is lubrication, but oil pressure is NOT lubrication. Oil pressure is only a measurement of resistance to flow. Running thicker oil just to up the oil pressure is the wrong thing to do, because that only reduces oil flow/lubrication. Oil pressure in and of itself, is NOT what we are after.
• The more free flowing thinner oil will also drain back to the oil pan quicker than thicker oil. So, thinner oil can help maintain a higher oil level in the oil pan during operation, which keeps the oil pump pickup from possibly sucking air during braking and cornering.
•The old rule of thumb for desired oil pressure, that we should have at least 10 psi for every 1,000 rpm, pertains to, and is highly recommended for High Performance and Racing engines. Engine bearing clearances are primarily what determines the oil viscosity required for any given engine. (NOTE: Viscosity does NOT determine an oil’s wear protection capability, like many people think. Wear protection capability is determined by an oil’s additive package, which contains the extreme pressure anti-wear components. That is why 5W30 oils can perform so much better than thicker oils in my wear protection capability testing). But, whatever the bearing clearance, for High Performance and Racing engines, it is best to run the thinnest oil we can, that will still maintain at least the old rule of thumb oil pressure, even if that means using a high volume oil pump to achieve that. A high volume oil pump/thinner oil combo is much preferred over running a standard volume oil pump/thicker oil combo. Because oil “flow” is our goal for ideal oiling, NOT simply high oil pressure. So, one of the benefits of running a high volume oil pump, is that it will allow us to enjoy all the benefits of running thinner oil, while still maintaining desirable oil pressure.
But, for normal daily driver street engines, it is acceptable to use the old rule of thumb only as an “approximate” general guideline, not an “absolute requirement”. And for those engines, no matter what their bearing clearance is, it is best to run the thinnest oil we can, that will still maintain at least “reasonable” oil pressure, that is not too far below the old rule of thumb oil pressure.
Using thicker oil just to achieve higher oil pressure, will simply reduce oil flow for no good reason. The oil pump relief valve determines the max oil pressure an engine can make, no matter what the oil viscosity is. And in some engines, the relief valve limits oil pressure to a max of 65 psi. But, that does not mean the engine’s redline has to be limited to exactly 6,500 rpm because of that. Oil pressure does NOT determine the engine’s redline, the mechanical design of the engine does.
Plain bearings, such as rod and main bearings, are lubricated by oil flow, not by oil pressure. Oil pressure is NOT what keeps these parts separated. Oil pressure serves only to supply the oil to the clearance between the bearings and the crankshaft journals. Those parts are kept apart by the incompressible hydrodynamic liquid oil wedge that is formed as the liquid oil is pulled in by the spinning crankshaft. As long as sufficient oil is supplied by the necessary oil pressure mentioned above, no wear can occur. And the higher flow rate of thinner oil, supplies more oil volume to the main and rod bearings, which also helps ensure that the critical incompressible hydrodynamic liquid oil wedge is always maintained.
Thinner oil will of course flow out from the bearing clearances quicker than thicker oil will. But, by making sure there is sufficient oil pressure as mentioned above, the oil supply will always stay ahead of the oil flowing out, which will maintain that critical incompressible hydrodynamic liquid oil wedge.
• Oil flow is what carries heat away from internal engine components. Those engine components are DIRECTLY oil cooled, but only INdirectly water cooled. And better flowing thinner oil will keep critical engine components cooler because it carries heat away faster than slower flowing thicker oil can. This is especially important with plain main and rod bearings, since the flow of oil through the bearings is what cools them. If you run thicker oil than needed, you will drive up engine component temps.
Here are some comparison numbers from an 830 HP road race engine on the track:
15W50 oil = 80 psi = 265* oil sump temperature
5W20 oil = 65 psi = 240* oil sump temperature
Here you can see how the thicker oil flowed more slowly through the bearings, thus getting hotter, driving up bearing temperatures and increasing sump temperatures. And the thinner oil flowed more freely and quickly through the bearings, thus cooling and lubricating them better than thicker oil, while also reducing sump temperatures.
Here’s some additional background on all this – You might be surprised by how much heat can be generated just from an oil’s internal friction, though friction may not the best term to use here. It is probably better to think of this as the heat generated due to the shearing action taking place within the oil.
It is the shearing action of the oil between the crankshaft and bearings, while the engine is under a heavy loading condition, that generates the bearing heat that we are concerned with. The oil wedge formed as the crankshaft pulls oil in and around the clearance as it spins, is liquid oil. And since liquids cannot be compressed, the oil wedge itself is what carries that heavy engine loading (oil pressure serves only to deliver oil to the crank/bearing interface) and prevents the crankshaft and bearings from coming in contact with each other, once the engine is running. Cold start up after sitting, is when the bearings and cranksaft start out in contact with each other.
The difference in flow rate, and the difference in shearing generated heat, is why the viscosity used, makes a difference in bearing and sump temperatures. Thicker oil which flows more slowly and generates more heat from shearing, it is not carrying heat away and cooling the bearings as well or as quickly as it could, so that drives up bearing temps. This in turn, causes hotter oil to be coming out of the bearings and into the sump, which is why we see higher temps on a gauge. That is the opposite of what we want.
On the other hand, quicker flowing thinner oil, not only generates less heat from shearing, but it also carries heat away much quicker, keeping bearing temps down. And this means the oil coming out from the bearings, and going into the sump, is also cooler. And that is why we see the cooler sump temps. This is precisely what we saw with the road race engine example above.
If an engine is running hot, use a thinner oil to increase flow, increase internal component cooling, and help keep sump temperatures down. Keeping oil temps down is important to help keep oil below the threshold of thermal breakdown.
• Thinner oil will typically increase HP because of less viscous drag and reduced pumping losses, compared to thicker oils. That is why very serious Race efforts will generally use watery thin oils in their engines. But, an exception to this increase in HP would be in high rpm hydraulic lifter pushrod engines, where thinner oil can allow the lifters to malfunction at very high rpm. In everyday street vehicles, where fuel consumption is a consideration, thinner oils will also typically increase fuel economy. The majority of new cars sold in the U.S. now call for 5W20 specifically for increased fuel economy. And now Diesel trucks are increasingly calling for 5W30, also for fuel economy improvement.
• Relatively few engines are built with loose enough bearing clearances, to ever need to run oil thicker than a multi-viscosity 30 weight (though some may need a high volume oil pump). The lower the first number cold viscosity rating, the better the cold flow. For example, 0W30 flows WAY better cold than 20W50. And 0W30 flows WAY better cold than straight 30wt, which is horrible for cold start-up flow and should be avoided at all cost. And the lower the second number hot viscosity rating, the better the hot flow. For example, hot 0W30 flows WAY better hot than 20W50.
* The churning action of rotating and reciprocating internal engine components, along with oil spraying out from between pressurized components, traditional oil pumps with their old-tech spur gear design, old tech oil pressure relief valves, and overall windage, all contribute in varying degrees, to causing the engine oil to become aerated, which is exhibited by air bubbles/foam in the oil. Air bubble-filled foamy oil, is what typically causes engines running on a dyno to experience oil pressure drops, assuming they have acceptable oil drain-back from the top end, and are keeping the oil pump pickup submerged. Also, air bubble-filled foamy oil, is what typically causes engines being run hard in cars, to experience drops in oil pressure, assuming the oil pump pickup is still submerged in oil. And if that isn’t bad enough, air bubble-filled, foamy oil cannot lubricate critical internal components properly. For proper lubrication of critical components, you need incompressible “liquid” oil, NOT compressible air bubble-filled foamy oil.
This is an issue to take very seriously, if you want to provide your engine with the best possible lubrication protection. If this aerated oil issue is bad enough, it can cause wear, damage or outright engine failure. And it can be extremely difficult to diagnose, in the event of an outright engine failure. Because when you take the engine apart for examination, you typically can’t find anything wrong at all, other than say the rod and/or main bearings that failed. That’s because the air bubbles/foam are long gone by then.
You can’t do much about the churning action of rotating and reciprocating internal engine components, nor can you do much about the oil spraying out from between pressurized components. Though you can try to reduce windage problems by selecting the best oil pan designs. You can also select a superior smoother flowing gerotor oil pump design with its internal bypass relief valve. But, the one thing that is the easiest to change to reduce engine oil aeration concerns, is to choose the proper engine oil viscosity.
Heavy thick oils such as 5W50 and 20W50, that are of course 50 weight oils at normal operating temperature, are slower to release and eliminate air bubbles/foam, than thinner oils such as 5W30 and 10W30 that are 30 weight oils at normal operating temperature. Motor oils do of course contain anti-foaming agents to help control (though not altogether eliminate) air bubbles/foam. But, the air bubbles that will still be present in the oil anyway, have to travel through the oil to be released. And thicker heavier oils slow down that process, leaving compromised lubrication. Adding aftermarket oil treatments that thicken the oil more, makes aeration issues even worse, by causing further slowing of air bubble release. Data on this is not widely published, so I have future testing planned that will provide much needed test data on this subject. But in the meantime, keep in mind that thinner oils such as 5W30 and 10W30, allow air bubbles to travel through the oil and be released quicker, making them a better viscosity choice to fight motor oil aeration issues, and provide the best possible lubrication protection for your engine.
• Thicker oils DO NOT automatically provide better wear protection than thinner oils, as some people mistakenly believe. Extensive “dynamic wear testing under load” of approximately 200 motor oils, has shown that the base oil and its additive package “as a whole”, with the primary emphasis on the additive package, which is what contains the extreme pressure anti-wear components, is what determines an oil’s wear protection capability, NOT its viscosity. In fact, the test data has shown that 5W20 oils can provide INCREDIBLE wear protection with over 120,000 psi load carrying capability/film strength/shear resistance, while 15W50 oils can sometimes only provide UNDESIRABLE wear protection with less than 60,000 psi. So, DO NOT use thicker oil under the assumption that it can provide better wear protection for our engines, because that is simply NOT TRUE.
BOTTOM LINE: Thinner oils are better for most engine lubrication needs.
Must_Tang
MA
Also from 540Ratblog:
7. 5W20 Quaker State Ultimate Durability, API SN, GM dexos 1 approved, synthetic (gold bottle) = 121,396 psi
zinc = TBD
phos = TBD
moly = TBD
This oil was tested Fall 2015. The psi value of this oil, which came from testing it at the normal operating test temperature of 230*F, put it in the INCREDIBLE Wear Protection Category.
However, I went on to also test this oil at the much higher temperature of 275*F. At that elevated temperature, any hotter and thinner oil is expected to experience a drop in Wear Protection Capability. And this oil did have a significant 23% drop in capability. However, even at that reduced value down to 92,893 psi, this much hotter and thinner oil was in the OUTSTANDING Wear Protection Category.
EFI
Masshole central
5.Br0
Key word there being "most". Noone is arguing that on a street car that sees day to day driving a 5w20 oil is not the proper viscosity.
This thread was started in the Road Course section specifically for track use...not street use. Two completely different driving scenarios and engine use, thus the "most" in your quote does not necessarily apply to this.
Must_Tang
MA
Question to you [MENTION=15869]EFI[/MENTION]: Have you read that blog? The entire blog?
EFI
Masshole central
5.Br0
I've read most of that yes, but it's not the end all be all of oil information on the internet. It's one guys semi factual and opinion blog post...so I don't put as much weight on it as you seem to do.
Where I put most of the weight on is the information provided to me directly from the Ford engineers which 1) spent millions upon millions of dollars and counteless hours in R&D on oils and 2) actually built the engine I am running in the car. Not some random cat on the internet with a bunch of spare time on his hand and a keyboard :)
