Norm Peterson
corner barstool sitter
I'll stipulate to the higher redline, quicker revving, and - depending on what the improvements were - the clutch. It's a stretch to call active exhaust an advantage unless it can be set to default to 'quiet mode' when starting and fully user-controllable (as in, individually switchable as opposed to being tied into whatever drive mode) otherwise.I have to question your use of the word "everything". You didn't even come close to addressing every advantage I mentioned. Active exhaust, higher redline with a quicker-revving engine, improved fuel economy, improved clutch, Android auto, LED headlamps. All of these things will be standard (except the exhaust? not sure on that one).
Personally, I think cars should be your sanctuary away from your phone and the people who expect you to be instantly available 24-7, which makes whatever Android auto is a non-starter. And that headlighting should be chosen on illumination performance alone (not on the specific technology used, IOW technology-neutral).
Perhaps the fight should be less about technological progress per se than about peoples' growing expectation that there need be no end to what technology should be doing for them.I understand your concern and feel some of it myself, but I'm not sure what the solution is. Do we just try to fight technological progress out of fear of what it will bring?
Not sure either. But maybe if driving itself went back to being an earned privilege instead of the rubber-stamped entitlement that it has effectively become . . .And if we don't figure out a way to draw a line (and I don't see how we can), then the AI revolution is inevitable. I'm not sure what happens to the human element at that point...
Norm
