thornclaw
- Mar 24, 2020
- northbrook, il
- 2015 mustang gt
perusing the threads here, there is generally a very noticeable bias against camber bolts. mostly, no good explanation is given as to why. Likely they are more difficult to adjust. Also, you would likely not be able to apply as much negative camber as a plate, as the wheel may eventually rub against the shock. However, they will not add any NVH like a plate will. For someone who plans on setting the camber one time and to a nonextreme degree and leaving it, it seems like the bolt would be a good option. Has any one had a camber bolt fail? Any real world experience/feedback would be appreciated.
