Cam drive / timing kit
Deca
NY
17 GT350
Hello- does anyone have the part# of latest timing kit or parts for 2017 GT350?
thanks, much appreciated
honeybadger
Just don't care
COTA
Kevin
'17 GT350
It's cheapest to buy the parts separately. I just bought this from White Bear Lake Autonation
Here's my recent parts list
Part Number​
Part Name​
Price​
Quantity​
Total​
GR3Z-6268-A​
Timing Chain​
$42.00​
2​
$84.00​
BR3Z-6268-A​
Secondary Chain​
$16.32​
2​
$32.64​
BR3Z-6B274-A​
Chain Guide​
$19.68​
1​
$19.68​
BR3Z-6M256-A​
Guide​
$19.08​
1​
$19.08​
GR3Z-6701-A​
Rear Main Seal​
$45.24​
1​
$45.24​
BR3Z-6020-C​
Timing Cover Gasket​
$11.34​
2​
$22.68​
BR3Z-6020-B​
Front Cover Gasket​
$8.89​
1​
$8.89​
CR3Z-6K255-A​
Engine Timing Chain Tensioner​
$15.84​
2​
$31.68​
XW4Z-6700-B​
Front Crank Seal​
$13.80​
1​
$13.80​
CR3Z-6L266-A​
$51.48​
2​
$102.96​
BR3Z-6020-D​
Front Cover Gasket​
$8.27​
1​
$8.27​
Deca
Deca
NY
17 GT350
Awesome, thanks. I understand Ford Performance came with improved parts? I believe adjusters?
honeybadger
Just don't care
COTA
Kevin
'17 GT350
you're probably looking for Ford Performance M-6500-M50R
They're the GT350R lash adjusters and became standard in all GT350s in 2019 (IIRC)
Deca
Deca
NY
17 GT350
Thanks again @honeybadger - shouldnt the parts be Ford Performance btw? I believe they’re ‘stronger’ than general Ford as per your list?
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Lots of Ford Performance parts are just parts developed for special edition models that are released to the public...in this case, the GT350R
Deca
Deca
NY
17 GT350
I’m putting in all new timing stuff and vct phasers, opg- should the parts be lubed/oiled before installation? See different opinions on soaking the chains a night etc. Thanks
honeybadger
Just don't care
COTA
Kevin
'17 GT350
Things like chains, tensioners, phasers, etc. don't need to be pre-lubed before install, but you should absolutely prime the engine with oil before you start it the first time. Basically you need to connect a pressure cannister up to the inlet port on the oil adapter and inject pressurized oil into the system.
Deca
Deca
NY
17 GT350
thanks- I thought to use the oil priming procedure of the vehicle itself, or that won't suffice? here's a video GT350 oil prime
honeybadger
Just don't care
COTA
Kevin
'17 GT350
that'll make sure there's oil in the lines and such, but it'll still turn the engine over without tension and lubrication on the timing components, which isn't ideal. It's better than nothing - but priming externally per the service manual is best.
K4fxd
NKY
2017 gt, 2002 FXDWG, 2008 C6,
Always soak chains before using them. It costs basically nothing and reduces initial start up wear.
Call it cheap insurance.
Deca
Deca
NY
17 GT350
thanks - what tool do you use to inject pressurized oil? and do I take out the oil pressure sensor and use as specific adapter for there or is there a specific port?
honeybadger
Just don't care
COTA
Kevin
'17 GT350
I used an accusump that I had plumbed into the system. But I've seen others rig up a garden weed sprayer to the oil pressure port
Timbuck
Australia
Tim
2017 s550
Or this is a simple alternative. Check out his TT mustang on other video’s. He is on here too.
Deca
Deca
NY
17 GT350
thanks everybody - looks easy enough...I just cannot find where to connect the sprayer, is it the oil pressure sensor? ie take that out and find somekind of fitting that screws in and a nipple for the hose of the sprayer?
