Boost by Gear with OEM Logic
That's what I'm getting at, it does re "scale" the APS
Yes and no. The way he set up the tables he posted it will give full power till it hits the limit.
If you look.at the table it is scalable by RPM.
mejohn50
mejohn50
Intergalactic Snail
United States
Mitch
slow junk
It does not give full torque until it hits the limit.
It gives requested torque up to the limit. Nothing beyond. The throttle pedal works like normal until it requests a torque value that is higher than the limit, then it goes dead with any more input until the limit is higher than the request.
Grimreaper
Dallas
2017 GT
Another layer of flexibility is the manual trans ecu has a DD table for each gear. So if you want to scale for first, you can keep a more linear pedal across 500ftlbs or what ever the tires can put down
I meant it will not limit power till it hits the limit. If you press 50% and that is 300 ft lbs that is what you get.
If the limit is 250 a d you press 50% you get 250
Or once you hit the limit the pedal does.nothing
