Auto Transmission Clunk
Coyote Red
Port Lavaca,Tx.
Alan
2016 5.0 Coyote Red
Interesting thread, following. I will monitor my 6R80 as well.
gov cheese
darksideofthemoon
2016 3.7 051A Guard
i had this same problem Ford tech found excessive play and replaced the transmission flange. Seems to have fixed it 8000 on the new flange and no clunk.
NOTE: my car has the dreaded 50-70 mph vibration the new flange made it worse. Ended up having to do the hose clamp on car DS balancing.
s550v6
Long Island
2015 mustang V6
What did you tell your dealer when you brought it in for the clunk? I've taken my car to 2 dealers and they insist nothing is wrong yet I hear this noise almost every time I shift into D or R, accelerate, or decelerate.
Contact "Ford Service" on here, her name is Deysha. Explain the problem in the PM to her; she will need your info, VIN, name, etc. and she WILL elevate your concern to your Regional Ford CSR, who will in turn make your vehicle a priority at X-Dealer.
FordService
Ford Customer Care
Dearborn, Michigan
Mustang
Definitely send me your VIN, dealer, mileage, full name, and best daytime number, s550v6. Also send me a brief description of the concern you’re experiencing.
Thank you for the mention and support, Cobra Jet!
Deysha
s550v6
Long Island
2015 mustang V6
Deysha
I will have that information for you within the hour. In the meantime I have a question...I have been experiencing this noise for most of my 17k miles and have brought it in 2 or 3 times to get checked out. Since no dealership took any action fixing it I figured it was normal and recently added a differential bushing support system from BMR. The more solid mounting of the differential has made this noise even more pronounced. Do you think it will be an issue that I have this modification done even if I have physical proof of me trying to get the noise fixed before the modification? I don't want a $60 mod to effect the possibility of a warranty-covered issue being resolved. What do you think?
FordService
Ford Customer Care
Dearborn, Michigan
Mustang
You will need to speak with your service manager about this, s550v6. He is in the best position to assist with this information.
Deysha
Cyber_Dude
Germany
2017 Mustang GT
Clonk when putting in reverse gear on AT
There is a Ford advisory out for this problem - if Ford Germany has it, Ford US has it definitely;-)
The solution is to disassemble the propshaft flange, apply some special grease and reassemble with a special nut.
Hope you get it sorted. Mine has it, too and I have an appointment to get it fixed. Others in the German Mustang6 Forum have reported back that this resolves the problem, so am confident resolves the problem.
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
Would this solution solve the clunk/thud on manuals as well?
It is a real shame Ford put these cars together with such loose tolerances, it is shoddy to be honest to have so much slack in the drive line on a brand new car.
Cyber_Dude
Germany
2017 Mustang GT
Gibbo205: The original post was for automatic transmission and my post was geared to that. I have no knowledge when it comes to manual transmission.
Do you by chance have or can get the Ford SSM Advisory notice number or a scan of the doc to post up so others can reference?
s550v6
Long Island
2015 mustang V6
I second that!
Cyber_Dude
Germany
2017 Mustang GT
Sorry there was no reply from me but I really tried to get the information and was unsuccessful. Mine ist still going in for the modification but my Ford dealer was firm on not giving out any Ford-internal advisory information. However, any Ford dealer should find the advisory using the problem description...
Good luck!
Coyote Red
Port Lavaca,Tx.
Alan
2016 5.0 Coyote Red
A "TSB"? Technician Service Bulletin? I am getting a thud when turning and sometime when I start moving forward, last time I noticed it I could reproduce the thud, then it goes away for a while. I don't "Hot Rod" my pony, just run thru the twisty's fast. No burn outs, just chicane's and S-curves.
Dominant1
Dr Frankenstang
2016 gt/cs auto 3:55 gears
Mine is gone after installing my one piece Dynotech Aluminum ds!
