Anyone know how to disable magnaride?
Niz55
Us
17 GT350
I am interested in buying a kw club sport coilovers but I need a way to disable the magnaride .can it be done ?
Niz55
Niz55
Us
17 GT350
Unfortunately you need to buy the coilover kit in order to get the deactivation kit.
Niz55
Niz55
Us
17 GT350
I am looking into that also. But I am not sure if i want to replace the lower arms with the GT model.
300blackout
CA
Jason
AMG GTS
Curious why after-market coilover kits over Magnaride or Magnaride w/ DSC controller? Curious what the benefits are..thanks..
Niz55
Niz55
Us
17 GT350
Onve you lower the car on springs it will never drive and handle nice as it was stock
Austinj427
CO
2017 GT350
Guys say the DSC module really softens up the ride in street mode and helps the car quite a bit in track.
It's kind of a lot of money but it's probably a 10 minute install, if you didn't like it I'm sure someone would pick it up on here.
Competition Orange
Columbus, Ohio
2017 GT350
You're on the progressive eibach springs right? Probably the issue right there.
No no, no popcorns please! It was an honest question. I had KW Clubsports before and I'm curious if Magnaride is better or worse.
Very few even have the DSC controller, and I'd be shocked if anyone has had it, AND a race caliber traditional coilover setup to provide any real world opinions. And then you'd have to figure out if said person who HAS is even a good enough driver to listen to his opinion.
Mach4.6
LBC
Paul
17' GT350R, 11' GT500, 07' GT500, 04' Mach 1
Corn is popping.
Bench racing incoming :)
The DSC controller is only going to do so much with the factory damper, it's not going to beat a dedicated race shock's control over damping and rebound.
Running coil-overs gives you more options of tuning with different spring rates (I'm running 450 front and 800 rear), changing the your ride height, adjusting your Rake.....
not to mention it saves a bunch of weight also
DCS is coming out with there own electronic damper for the 350, I'm sure they're not cheap so I'll wait to hear some feedback on them
