Anyone here running 285/295's in the front?
Zax
Naples Fl
Zac
2021 Mustang GT Roush Stage 2 SC
285/35/19 19x10 +35 all four corners here. A square setup drastically improves cornering and handling imo plus the added benefit of being able to rotate front to back. Not ideal for a drag/straight line setup but if your goal is handling the square setup is king
Did you use any spacers up front? I would be thinking 285 or 275. Premium tries
dead_inside
PNW
16 GT Prem PP
Nope, no spacers. This is an “easy button” square setup as a lot of guys here run this combo and there is a lot of info available on their experiences. There are plenty of tire choices at that size as well. I don’t notice much, if any tramlining at 285 either. So I like that for a primarily street setup.
Grintch
Hunstville
2015 GT PP
+35 doesn't require a spacer but can be a bit borderline pokey in the rear depending on camber.
I use +40 wheels with a 5mm spacer up front (gives you effectively +35). You only need the spacer up front with wider than average 285s.
Zax
Naples Fl
Zac
Ok awesome! Good to know. Thanks for getting me started on the research path
Zax
Naples Fl
Zac
That makes sense. Requires a minimal spacer and will save the rear fender from rocks being thrown from the sticky tires
dead_inside
PNW
16 GT Prem PP
What Grintch is saying correct. Here is a pic of the rear for reference
Zax
Naples Fl
Zac
Thats the perfect reference there. It’s just the sidewall so it shouldn’t throw much into the fender. That extra 5mm would still help though….thanks
Dave2013M3
El Segundo,Ca
2020 Ford Mustang GT Base PP1 6MT Rapid Red
Here is my 2020 GT PP1 with SVE X500 19X10 &19X11 with Mich PS4S 285/35/19 front and Mich PSS 305/35/19 rear. A 295 will fit on a 10" wide wheel but won't be optimum. GT350s have a 10.5" front wheel for their 295s.
Bridgie
Raleigh, North Carolina
2015 GT fastback. PP, 50th trim, Black
Track set-up is: Toyo 295 Squared on EC7 Apex 18 x 11 wide rims ET 52 and 25mm Spacers.
Road set-up is: MP4S 285 Squared on R350 SVE wheels 19 x 10, no spacers
Have OP Mustang GT4 Lengthened studs fitted.
Currently running F & R at -2.75Deg Camber, will be lifting maybe an inch and going to -3.0 deg before VIR in a few weeks.
Fronts: have Vorshlag Caster/Camber plates (with opened strut hole), bumpstops etc...
Rears: have adjustable Steeda Camber arms & Toe links
Bear380spin
Monterey
Jonathan
2021 5.0 manual
What’s your camber in the front and back?and is lowered ? Looks really good
NightmareMoon
2016 Mustang GT PP
Thing is, the rear fender behind the wheel doesn’t seem to pickup rock chips or really any wear from wider an/or sticky tires.
I have 88k on my GT with most of that running mostly 285 ET35, with some thousands of miles of 305 ET52, and now 315 ET50 rear tires and the rear fender paint behind the wheel looks better than about every other part of my car, it still looks new.
The front of the rear fenders ahead of the wheel are another story,
Zax
Naples Fl
Zac
I ended up buying the Ford Motorsports 9.5 front 10.0 rear wheels. I figure that will help save the rear fender some with rock damage. Tires 305/35 rear maybe 285/35 front rims are 19. It has the Roush stage 2 SC so I decided against the 285 sq setup.
