Logical analysis, as are your questions. I am in a cold climate. The engine was not fully warmed up in that clip and it was less than 40* outside. I'll have the wife shut the car off a few times so I can stand right over the engine and place my hands where I sense anything. I'll also verify underhood connections, etc.It's not fast enough to be something rotating internally. Almost sounds like air escaping from a blow off valve.
Some guys experienced a pop from the intake on shut off intermittently from air pressure. My car did it when I unplugged the throttle position sensor during a part install. Took a few drive cycles for it to relearn itself. I think you have something loose or the throttle body is learning itself.
Are you in a cold climate or high elevation? Check all your sensors to be sure they are attached and see if the noise is originating from the throttle body. I would almost bet my lunch that is where it's coming from
I can't tell over all the fun they were having!
Listen to about 13:25 on, specifically around 13:28. There's a sound that I think sounds similar to that that you can hear. Could it be the CMCV's sticking? I believe the 350 IM has them.
I'll be in a position to answer that when Mother Nature decides to cooperate.With 6 miles, is it still in factory transport mode?
Subscribing to this theory.It's not fast enough to be something rotating internally. Almost sounds like air escaping from a blow off valve.
Thanks - what does IRC stand for? Google didn't help.Sounds like IRC is acting up. See if the noise is coming from there.
