Ambient Thermal Management
Alright guys, we'll come up with a solution to recirculate Will most likely be an adapter for our charge pipe and a hose to connect to the factory plumbing.
I'm thinking the same thing. It wasn't TOO badly corroded, you can tell it's seen some salt, but a coating would really help extend it's life.Looks like powder coating will pay dividends over the life of the car in corrosion protection. Salt is not kind to bare aluminum! I see a bunch of oxidation on the top of the bottom half.
Those are good results. I wouldn't worry about charge temps while cruising under vacuum. When there's no boost there's very little thermal transfer because the air density is so low.I'm thinking the same thing. It wasn't TOO badly corroded, you can tell it's seen some salt, but a coating would really help extend it's life.
From initial testing this morning driving to work, it hasn't affected the performance of it! It was warmer this morning by about 15 degrees over my last huge testing of the stock intercooler and this one stayed at roughly 40 degrees delta. It was 80 degrees. Cruising on the interstate showed about 87/90 degrees fluctuating but with 0 boost. City cruising seen about 91 average.
But the real magic is when you ever so slightly push down the gas, it drops like a brick. The HIGHEST delta I seen during a pull this morning was 6 degrees over ambient. Granted this is a small collection of data points, about 4 pulls, so 12 or so gears. But the entire pull the intercooler continues to drop temperature. you'd NEVER see that on the stock. Best part is on the one mile stretch up to my works driveway...Still had every ounce of power it had when I started it up this morning. Something I could never say on the stock.
*side note...Installation of this behemoth absolutely sucked lol. Do not do it at night.
Not worried about cruising temps in the slightest. Not sure where I actually got that delta number from. Delta while cruising was about 15-20.Those are good results. I wouldn't worry about charge temps while cruising under vacuum. When there's no boost there's very little thermal transfer because the air density is so low.
Air to Air exchanger's only really work when the fluid density is high as there's a much higher concentration of air molecules that are able to touch the aluminum and conduct heat to the cooler ambient air.
That's why you see high temps while cruising even in the highway compared to WOT. I doubt I"ll see a huge difference between the already good Levels Gen 3 20x14x3.5 which is pretty big, however I'm expecting to see about a 10F drop over the Levels based on what your seeing and what was logged in that 2-3-4 gear pull they show on their site.
I'm thinking flow at high RPM will be a little better too, may pick up a few HP on the top end. I'm thinking the combination of the Ford Performance Calibration and this inter cooler will be an amazing factory like setup (as in warranty safe because of the FP calibration). The way to make the car faster (than just what the tune offers itself) with the FP Calibration are the more traditional changes such as efficiency modifications like lowering the vehicle weight, gearing, ram air ducting, better cooling, better human inter face, better tires etc instead of just trying to get more power out of the engine (hence why a fair amount of the shop tuned cars have grenaded on customers).
If you pop and engine, you should just bought a GT from the get go because a replacement 2.3T is the cost difference between the EB and GT...
100% fit stock pipes. Just did the install on Wednesday.This can use the factory charge pipes without an adapter?
Or other (hard) charge pipes that use the stock FMIC connections?
How does this compare to the Wagner EVO1 or EVO2?
I'm in "Swampass" TX and need MAX cooling - it was a heat index of 108*F at the track yesterday!
Yes you can use the factory charge pipes. Honestly I think the primary reason to replace the charge pipes is for reliability, especially if your running an aftermarket tune, including the FP Calibration as I've hit up to 25 psi on the FP Calibration.This can use the factory charge pipes without an adapter?
Adam would disagree. He's tested numerous CAI's and still to this day says stock airbox will give you the most power. He actually did a live feed of testing all of them.Yes you can use the factory charge pipes. Honestly I think the primary reason to replace the charge pipes is for reliability, especially if your running an aftermarket tune, including the FP Calibration as I've hit up to 25 psi on the FP Calibration.
That's why I replaced my charge pipes, because I had them loosen up on me twice in six months during the winter when the stock rubber couplers and plastic tubes shrink at different ratios, they become leaky where aftermarket silicone couplers or high end woven rubber couplers combined with aluminum or silicone charge pipes tend to be more temperature stable and stay clamped tight regardless of hot or cold.
AEM's dyno showed a bit of a gain in power, about 7 HP around 5500 RPM most likely due to the slightly more graduated bend radius coming out of the compressor outlet. Air flow doesn't like sharp turns or you incur pressure loss.
If I did it again I'd go with ATM's silicone charge pipes IF they made it with a re-circulation option or Mishimoto's as they use t-bolt clamps and silicone couplers.
The AEM's aren't bad, they work just fine, but their fitment wasn't quite as good as I would have expected and the Mishimoto's / CP-e's have an even more gradual bend radius. Any of those 3 I would recommend. I think the silicone provides the best seal where AEM uses a high end rubber (like a tire rubber compound). They are better than stock, but not as easy to work with as silicone.
A good CAI and charge pipes will make a difference in response, especially when tuned as well as add a little power. All engines like to breathe, regardless of FI or NA. There are gains when tuned with a high flow intake, you simply can't pull as much air through the stock panel filter as you can through a large conical filter nor can you push as much air through a sharp bend radius as you can through a graduated radius.
All these things add up to minor inefficiencies when combined open up response and add a little power / torque.
He also has blown customer engines...but of course he must know more than an entire team of Ford and Ford Performance engineers with 20+ years experience...Adam would disagree. He's tested numerous CAI's and still to this day says stock airbox will give you the most power. He actually did a live feed of testing all of them.
You're right. Why would companies SELLING intakes say their product is inferior. A little biased huh? Atleast those intake supercharger fans work because their company says they do!These guys must ALL be wrong...:
http://www.atpturbo.com/platform/MustangEcoboost.html
https://www.*******************/forums/threads/steeda-ecoboost-mustang-cai-install.1106760/
https://www.speedfactoryracing.net/mustang-ecoboost-dyno-data
https://www.steeda.com/steeda-proflow-ecoboost-mustang-cold-air-intake-2015-ecoboost-555-3199.html
