4.09 gears.
Conedodger
Ca
2017 GT350-R
I'm building a complete diff for the car so I can swap between gear sets as needed. I am also going to swap in a CF drive shaft when I do the swap.
Hack
Minneapolis
Mustang, Camaro
I love the idea of having two diffs.
Hi-PO Stang
Minnesota
2014 Shelby GT500
I think all Mustangs as delivered from Ford will benefit with more rear gear. Ford does not put the optimal gear in the Mustangs because of CAFE. A 4.09 gear sounds good, a 4.56 would be interesting.
MRGTX
CT
2020 Mustang GT 6spd base
That's what I suspected. I can't imagine how awesome these cars would be with 4.56 final drive, fuel economy be damned.
Any insights on what a quick-change differential might look like would be very welcome. The only analog that I'm familiar with is the ancient Chrysler 8.75" with a very easy to swap center section (out the front of the axle assembly).
pinero61
Houma, La
'15 Ruby Red Base GT PP
With aftermarket axles, these are fairly easy to swap out.
jma406
WI
17 GT350,1962 406 S/S,64 Falcon B/FX, BOSS KK1215
I took the plunge and ordered M-4209-88409A and M-4210-B3 for my GT350 R. I will let you all know how it works out in a couple of weeks.
You may want to call Ford Performance to find out why the 4.09 gears were dropped. I had a conversation with them months ago about this.
Next Phase
NC
Mopar
Do tell...:gossip:
stanglife
Jeff
1993 Coyote Coupe
So what do you do with the ECU to correct for these gears?
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
You can use a whipple device or forscan if your talking speedometer correction.
Conedodger
Ca
2017 GT350-R
Update: Estimated ship date 3/3
BTW, there is a 3.91 available also.
Conedodger
Ca
2017 GT350-R
Update. The gear set arrived today so they do exist. That is the first hurdle crossed.
Voodooo
SE Michigan
Scott
