2018 Royal Crimson F1A94 Procharged, TH400 Drag Project
olaosunt
Indiana
Since you have a “core”
$4700 For long block .
$2000 for short block .
80FoxCoupe
Cincy, OH
16 GT, 80 Fox
turnswrench
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Better pricing than I found. Everything I found was $7k+
olaosunt
Indiana
Better pricing that found. Everything I found was $7k+
Those prices are for OEM/stock .
i think your heads are good right ?
Add head studs .$250 .(and may be drop in Mahle pistons .No balance required )
Fortunately you can also do your own wrenching so you can be back making passes before you know it .... hopefully they are not back ordered too .
olaosunt
Indiana
Hey man
does Your momentary button for the transbrake also activate your 2 step or is that off the foot brake ?
turnswrench
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Hey man
Two step and trans brake are the same button.
5ohh_kenny
Indianapolis, IN
2019 GTCS
Hey man
I also have my 2 step activated on the same button as transbrake but I have mine setup so I can turn off the transbrake and just activate the 2 step on a button. Seems like my footbrake can hold the car on the 2 step at 3200rpm and 8psi. Haven’t tested it at the track yet so we’ll see. 10r80 second gear leave
rainmaker
NW Indiana
2015 Mustang GT PP
@olaosunt - I have my 2-step setup to activate off of the trans brake button OR it will also activate with the footbrake via a momentary button on the brake pedal (for footbrake only racing). Lemme know if you want some pics ;-)
olaosunt
Indiana
rainmaker
NW Indiana
2015 Mustang GT PP
Sorry for the delay and thread hijack. Footbrake uses ground activation for 2-step and transbrake uses 12-volt activation so you can have both options hooked up and ready to use
turnswrench
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
Been a busy few weeks around work and the house - but not much on the mustang. I appreciate all of the advice and guidance, but things are looking tight this year. It may just not happen soon. Sucks to see the car sit, in pieces, but it is what it is. I'm not giving up, just aligning expectations, even for myself.
turnswrench
turnswrench
turnswrench
MN
Bowman
F-150, WK SRT
All, I'm thankful to share that @fordsvtparts (Mike R) of AutoNation Parts White Bear Lake, MN - a sponsor of the forum, has helped me order a factory long block. I'm immensely gracious and can't wait to get the car back on the road. Once I get the car going again, I'll be focusing on a sleeved build that will take time based on how backlogged shops are and how back ordered parts are.
Stay tuned for more. In the meantime, support this vendor if you can. It is mutually beneficial.
PUMPED!
NGOT8R
Adrian
2019 Bullitt
PUMPED!
That’s awesome man! Are you going to back off on the power a bit to help it last until you get your built motor ready? You can still get your NHRA license and work on your sixty and reaction times, to stay sharp and ready for when the built motor goes in.
