18x10+42 CF5 + 5mm spacer +camber bolt question
strengthrehab
Houston
Ken
2016 DIB Base GT with PP
I have my wheels mounted on my car for my track setup. No spacer was required for clearance. Thing is, I also had an alignment with camber bolts and camber was maxed out at -1.3 with wheel very close to the strut.
I ordered 5mm spacers in hopes the spacer will allow enough clearance to increase camber with camber bolt. If not, I will just get plates.
Will I be able to get more camber?
Paul@PKAUTODESIGN
The Wheel guy
Los Angeles, California
WWW.PKAutoDesign.com
Paul A.
The car looks great brotha, honestly You may be able to just get a tad but more but not much to be honest with you.
tyshenry
DFW
'15 GT w/ PP
With a 5mm spacer you should have room to get -2*. I have 19x10 +35 and was able to run -2.1 with no issue.
BmacIL
Enginerd
Naperville, IL
2015 Guard GT Base, M/T
Thanks for this. Glad to know an 18x10 +42 fits without issue to the strut.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
Its only a matter of 2 mm brotha, it would fit just fine.
strengthrehab
Houston
Ken
I did order and will install tomorrow the 5mm spacers. Still not sure if I will bother trying to get more camber. I only need 0.7 degrees.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
Doesnt hurt to try right.
BmacIL
Enginerd
Naperville, IL
I've seen pictures of 20x10 at +40 that were pretty darn tight to the strut, so I figured +42 might be getting a little close for comfort.
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
It is but it works, just comes down to the tire bring used.
ihavefat
GA
'12GT/FoST/'16 GT
was that really all the camber you could get up front? I have -2.5 on slotted struts and i do not rub (I am still on stock wheels). Most likely I will go the spacer route if I can get my hands on decent track wheel setup
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
Well what kind of track setup would you be after?
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
Track setup you say? Let us know when you are ready, we have setup many of our clients with track sets for their GT, GT350, and GT350R.
Any particular width and diameter you are looking for?
earlingy
Rocket City, AL
2016 Mustang GT Premium Performance Package
Those 18's fit over the Brembos and look good, I'm jealous... what size tires?
Paul@PKAUTODESIGN
The Wheel guy
Paul A.
