Jstang23
According to official mustang service intervals the Transmission fluid does not appear in any of the milestones from 0 miles to 100k.If I recall correctly on my 2013 2SS Camaro, I believe they changed the transmission fluid around 25 to 30,000 miles.
This 10 speed is very very different from any other transmission you've likely had and uses the ultra low viscosity fluid. I am not surprised to see no change intervals because of the complexity and efficiency of it. I would also not even think to touch it until 75k miles.
Also changing fluid is useless unless you start to have major problems. Changing fluid won't change any feeling or prevent wear. Trans fluid doesn't go bad slowly, you tend to burn it. So as long if you haven't trashed your trans it should be good to at least 75k!
