- Apr 13, 2015
- Malvern, PA
- 2014 Track Pack 5.0
Hey guys,
I've had to keep these things a secret for a little while but I am excited to say that the Diffuser Fins for the base bumper are officially OUT and ready for purchase!
We just got a set installed on Brian's SICK S550 and pics are incoming!
Check them out.
Check them out.
-WillMMD Rear Diffuser Fins (15-17 GT, EcoBoost, V6 w/Non-Premium Rear Bumper)
Aggressive Race Inspired Styling. Do you own a base model 2015-2017 Mustang with the Non-Premium Rear Bumper? Would you like to give it a more aggressive race inspired appearance? If you answered yes to both of these questions you should check out a set of Modern Muscle Design's Rear Diffuser Fins. These MMD Rear Diffuser Fins are a simple and inexpensive way to alter the exterior appearance of your base model Mustang.
- Aggressive Race Inspired Styling
- Smooth Matte Black Finish
- Durable, Injection Molded ABS Construction
- Simple Peel and Stick Installation
- Fits 2015-2017 GT, EcoBoost and V6 Mustangs
- Designed for Base (Non-Premium) Chassis Packages Only (Trim Levels: 050A/051A/100A/300A)
High Quality Construction. Manufactured from an OEM quality injection molded acrylonitrile butadiene styrene (ABS), these MMD Rear Diffuser Fins were designed using the original OEM CAD data from Ford to ensure a perfect fit. ABS is an extremely strong material known for its light-weight, superior durability and impact resistance - making it perfect to withstand the hazards of daily driven vehicles.
Simple Peel and Stick Installation. No messy glue or drilling is required for installation. These MMD Rear Diffuser Fins are designed to install simply with the pre-applied 3M doubled sided automotive bonding tape. Thoroughly clean the surface and then simply peel the 3M tape from the back of the Fins and set them firmly in place using the included push pins as a guide. It is that easy.
Application. These Modern Muscle Design Rear Diffuser Fins are designed to fit 2015-2017 V6, EcoBoost and GT Mustangs equipped with the factory Base (Non-Premium) Chassis Packages only (Trim Levels: 050A/051A/100A/300A). Not intended for use on Premium Package models.
