dgc333
For those of you that have not convinced yourself to buy and aftermarket shifter I ran across a very in expensive improvement.
Energy Suspension has a shifter bushing for $14 that utilizes the stock bracket. http://www.aftermarketsuspensionparts.com/4.1145.
It sharpens up the feel of the shifter and after seeing how flimsy the stock bushing is I can see why it does. Not sure how this bushing will compare to the Steeda bushing and bracket. The Steeda extruded aluminum bracket does not appear to be appreciably stiffer than the stock heavy stamped steel so any difference would likely be attributed to different durometers in the actual bushing material. Certainly won't be as solid as the Boomba bracket but with the shifter being hard attached to the floor I would think the Boomba will have a very noticeable increase in NHV, I didn't notice any difference with the Energy Suspension bushing.
For $14 and 20 minutes of your time it is a worth while mod
