Tune+
- Oct 13, 2015
- St. Paul, MN
- Website
- www.facebook.com
- Adam
- 2015 Ecoboost Mustang Automatic
PRE-ORDER IS LIVE!
http://adamtuned.com/collections/20...-port-injection-kit-for-2015-ecoboost-mustang
Well, most of you know that I have been working on a E85 conversion kit for the Ecoboost Mustang for some time now, and some of you ask me almost every week when you can purchase it. I'm sorry to keep pushing it further back but in order to release something it needs to be proven and go through testing before I am satisfied.
From the basic to the extreme I have finalized all my testing and have chosen the optimal injectors and configuration for each style of customer. Stock turbo, Turbo Upgrade, Turbo Upgrade and Built motor. Each had impressive results, and each performed flawless in regards to the fuel system. Stock turbo cars will be limited by the stock turbo, and upgraded turbo cars will be limited by the stock block, and built motor cars will be limited by the factory head gasket unless built with 12mm head studs and a custom gasket which is up next for testing on the 663whp/605wtq car.
The testing is done, and the next step is to bring down manufacturing cost on the different variations that will be offered. Here are the different stages in kits, all based off my love for burritos.
Lite Sauce - Designed for stock block cars for up to 450whp, with either stock turbo (400whp) or a turbo upgrade like our GTX2867R turbo upgrade kit.
Extra sauce - Designed for upgraded turbo and built engine cars up to 600whp. The kit is virtually the same but includes bigger injectors to support the additional fuel. To make up to 600whp it is recommended to upgrade the in take fuel delivery system. We will have a solution for this in the near future. A Boost-a-pump is NOT recommended, or considered to be a "fuel delivery upgrade" it can cause fuel driver failures on the Ecoboost platform.
Each kit will come with the following:
- Injection plate
- Fuel feed line adapter
- 4 x Injectors (Lite, Heavy, and Mega all use different injectors)
- Plug and Play Fuel Lines
- Fuel Controller
Optional equipment:
- Inline Fuel Filter
- Bluetooth Ethanol Content Sensor
If both optional equipment are chosen you will receive a 3D printed mounting plate to hold the filter and the ethanol content sensor to the intake manifold. Still in development but will be available in the future.
If you are a TUNE+ customer, or a Cobb Accessport customer (more than likely you are a TUNE+ customer at that point) you won't need to do anything with the Accessport if you want to switch back to pump gas. Simply map switch with your cruise control buttons to your pump gas slot, and turn the E85 injection system off. The controller will be wired to a switch to turn on and off when necessary. So you can drive out of state on E85, and if there is no E85 just switch off the kit and switch to your pump gas slot and off you go!
As mentioned above, the kit is now past the testing phase and now looking into reducing manufacturing cost. Final pricing will be posted soon, but currently the Lite Sauce kit will start out at $1,000 shipped without any options, pricing will drop if cost can be reduced significantly. Looking to drop the line and fitting quantity.
New pictures will be posted later this week once a few new pieces arrive. Going to be hand making one of the pieces and want to get it pressure tested before I move forward with final production pictures.
UPDATE: 6/6/16
Pressure tested a custom fitting last week, then put 150 miles on it this weekend to make sure there are no problems. I'm reaching out to a few machinist today to get some quotes on making a few things, then we should be good to go.
I will have final pricing on everything tomorrow hopefully, then we can start the pre-orders.
Here is the latest pull from the World Record run, the car made 48 pulls on the dyno this day, that last 20 were over 600whp. This is SB1Racing's vehicle and you can find his build thread below:
http://www.mustang6g.com/forums/showthread.php?t=41001
The car below is a MAP 5558 / Stock block car, been at this power level for over 2 months on E85.
I will have some dyno graphs from the stock turbo car I am tuning now, and is making 400whp as of last week with full bolt ons. The car is being put together for a customer in Kuwait, and will be shipping there soon once we finalize the tune/transmission.
Quick glimpse at the bluetooth ethanol content sensor hooked up and working on a Galaxy Note 4.
- Injection plate
- Fuel Controller
Optional equipment:
UPDATE: 6/6/16
