582hp/442lb-ft from factory, what do I need to do?
arsenalrocks
GTA
2016 GT350
saw this from the other forum:
not sure what that camshaft kit contains, maybe we already got it.
but looks to me with the cobra jet intake, TB you will get 582hp no problem
sign me up
mattlqx
Driver
Mesa, AZ
'22 Mach 1, '16 F-150, '14 Fiesta ST, '14 Audi A7
This is also with a cross-plane crank interestingly.
Voodooo
SE Michigan
Scott
Carroll Shelbys Soul Lives Under My GT350 Hood
:D I'm buying one now, I was thinking about a bigger throttle body. But I'm wondering about hood clearance.
Cobra jet intake
Cobra jet throttle body
CAI
ARH Long tubes
ARH off road X pipe
Notice it says long tubes and 101 octane fuel
Sweet Jesus
arsenalrocks
GTA
2016 GT350
you r right, it is for the cross-plane crank, due to the difference in firing order I don't think that particular cobra intake will work on the flat plane.
Nataphen
DFW
2013 Mustang GT
Firing order actually has little to do with these manifold designs. They're selling the Voodoo IM for the Coyote for example.
Voodooo
SE Michigan
Scott
Both cross or flat plane intakes will work.
1320'
Medford,Oregon
2011 Avenger...sadly
Also keep in mind...
*With 101 Octane Fuel and Long Tube Headers*
Note that those runs likely don't have an exhaust hooked up
More than likely with 91/93 Octane fuel and LT's through a full exhaust...
550 HP, 430 TQ...ish. Less torque probably, maybe 425 TQ.
Nataphen
DFW
2013 Mustang GT
Those cams are also not emissions compliant to my knowledge. The Voodoo had to be certified by the EPA. I'm sure we'll see some interesting numbers from it soon. The fact that it makes peak power from 7500-8000RPM with a long runner intake manifold is amazing to me!
Voodooo
SE Michigan
Scott
I'm ordering now intake and TB now
Voodooo
SE Michigan
Scott
Where do you see the cam specs. That part number isn't on ford performance yet
arsenalrocks
GTA
2016 GT350
minjitta
Houston
Andy
2014 Ford Explorer
on coyote i think you can skip the pistons and rods, and still get those hp
Voodooo
SE Michigan
Scott
My dealer just looked up those cam part numbers and according to him and ford performance those are the stock GT 350 cams
Nataphen
DFW
2013 Mustang GT
I assumed that they were the old Cobra Jet cams. They were 13mm lift, but the duration was way up there. I think 290 duration on the intake and 263 on the exhaust. I don't recall exactly.
Todd15Fastback
Atlanta, GA
Todd
2015 Mustang GT PP Fastback
Run E85 and be happy :D
