- Dec 20, 2014
- Lake Worth, FL
- Website
- www.uprproducts.com
- 15 GT
We have just finished the Single Valve Catch Can with Clean Side Separator for the 2015 Mustang GT's that run the VMP, ROUSH, or Ford Performance Superchargers.
Their is no cutting, splicing or anything to install this system!
Here is a TVS Supercharged installed by our friends over at VMP Tuning.
First thing we did was remove the Passenger side hose that connect to the back / bottom of the blower. You can see with only a few days worth of life, she already was having oil suck into the blower
What we did was instead of removing the line to the back of the blower, we blocked it off with a fitting and cap. This way you can keep it if you ever go back to factory with a simple re-install.
We tucked it out of the way and zipped tied it where you cannot even notice
Once this was complete, we started with the driver side hose. We have created a clean side separator which will keep any oil or contaminates from blowing into the intake tube and puddling up at the throttle body. As you can see, this is a simple swap.
Once this is completed, we started on the passenger side which we used our single valve catch can that mounts next to the radiator. With the supplied bracket and bolt, we mounted it to the frame.
Once the can is mounted, Run the line from the valve cover to the top of the can and the other line from the side of the can to the back of the blower.
*** YOU WANT TO MAKE SURE THE ARROW ON THE CHECK VALVE IS POINTING TOWARDS THE BLOWER ***
Then your done! This should not take more then 30minutes to install. I would start the vehicle and double check your install. Make sure everything is tight and connected properly.
This system will be on the website here shortly and pricing will be starting at $319.99 (Satin)
If you have any questions, please feel free to call us at 561-588-6630
Thanks!!
Thanks!!
