Aaron@Jpcracing
Guest
Just wanted to show a few logs I took from a bone stock 2015 Mustang GT.
Here's a quick view of the RPM to start off with. I nailed the rev limiter going 2-3, looks like the rev limiter on this car is set at 6800 rpm and is all done with the throttle blade, I let off for a moment between the shifts as well which can be seen on the logs.
A/F Ratio seemed to be about .82 lambda all through 3rd gear. It was pretty stable throughout. Looks like in second it trailed down from .97 lamda down to about .85ish.
Here's a quick look at the timing. Looks like it was getting 22-23.5 degrees of timing even with the knock sensors adding 3 degrees in part of second gear. Not sure what kind of fuel was in it, more the likely whatever it came from Ford with.
Just wanted to post up a quick view of the IMRC plates functioning.
