rear wheels not protruding equally - 2017 GT350
kart125
Montreal, Qc
2017 GT350/2008 Saab TurboX SC
Quick question... just noticed while walking up to car this morning that rear wheels are not protruding equally from fenders! I took some pictures.
What's causing this? Any easy fix?
Thanks for your input!
kart125
kart125
Montreal, Qc
I'd say it's about 1/2 inch difference. additional info: I installed R springs 3 weeks ago. Could it be the subframe that is not rebolted properly?
ChitownStang
Chicago, North Shore
2021 Mach 1
My 15 gt is the same, no suspension work. I'd love to know why as well
gotstocks
Madison, WI
C7 Z51
Did you get an alignment after changing the springs? If not, that is likely your issue.
Zombo
befejezett
2016 GT350 Track Pack - Race Red, Blk Roof - G5405
Drivers side looks to have a lot more negative camber, both front and rear.
kart125
kart125
Montreal, Qc
I have an appointment for alignment later this week. Will report back after. It might be the cause, I hope!
kart125
kart125
Montreal, Qc
After looking at the pictures and the car again I'm thinking that if it's just camber setting the lower left wheel would protrude more and the right side less. It looks like both top and bottom of right wheel are poking out more... weird! It looks like entire axle is shifted to the right 1/2 inch!
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
Salut Louis,
As others have mentionned, i would get an alignment ASAP as i'm sure your problem can be corrected by means of a camber adjustment.
Went to these guys twice, they're known in the business to be very good. Owner is a very nice guy.
Main thing is they are very careful and respectful with how they handle the work on your ride.
They do high end cars all the time.
Keep us posted.
Ctease
GT350
Make sure you have both rear wheels on the back. I once put front on back and back on front. My buddy put front on left and rear on right.
Guess next step is to start measuring.
dwalker
East TN
2017 GT350 white with blue stripes "H1807"
nastang87xx
Wisconsin
kart125
kart125
Montreal, Qc
I have an appointment at Garbis this week. I'll look at lowering the rear sub-frame again and rebolt it and maybe order the bushing kit. Is it easy to install?
kart125
kart125
Montreal, Qc
I'm assuming you loosed and dropped the IRS subframe to install the springs, correct? If so it's the whole subframe that's shifted to one side. There's a little play in the bolt holes, but Steeda actually makes some alignment pins/bushings just for this issue!
https://lmr.com/item/ST-5554438/201...qlIkx6RVPTPJKLkgo7uaq6zQ6c8bVZ8ts_BoCFHHw_wcB
That was my impression. But before dropping everything again I (I have the steeda IRS brace - needs to be removed also!) I wanted to have more insight into it... I will maybe try just to loosen up everything and play with the subframe and rebolt it. Thanks for imput guys!
montreal ponies
Montreal, Canada
‘17 Ruby red GT350
That's what i'm talking about . :thumbsup:
