MOTM: SC Ruby’s Whipple Build
by • March 8, 2016 • Mustang of the MomentComments Off on MOTM: SC Ruby’s Whipple Build8948
This Mustang of the Moment goes to SC Ruby (Dennis) and his supercharged 2016 Mustang GT!
Equipped with a 2.9L Whipple Supercharger this Ruby Red Mustang GT has a dizzying array of engine, transmission, suspension and cosmetic modifications to make for a vehicle that not only has power and handling well in excess of its stock capabilities, but also looks superb in the process.
See the full list of modifications below and check out Dennis’s 2016 Mustang GT journal in the forums.
Modifications List
Engine:
• Whipple 2.9L Supercharger
• Whipple 10 Rib Race Belt System
• ATI 10 Rib Harmonic Balancer
• 132 mm Elliptical Billet High Flow Throttle
• Whipple Enclosed Air Box
• Moroso Air/Oil Separator
• Whipple Dual Fans
• Whipple Upgraded 72# Injectors
• MSD Fuel Pump Booster
• Whipple High Flow Intercooler Pump
• TSS Billet Oil Pump Gears
• MMR Crankshaft Gear Billet Lower
• MMR Head Cooling Mod
Transmission:
• McLeod RXT Twin Disc Clutch
• McLeod Billet Steel Flywheel
• ARP Flywheel to Crankshaft Bolts
• McLeod High Volume Clutch Line
• Ford Racing TI-VCT Roller Pilot Bearing
• MGW Race Spec Shifter
• MGW Weighted Grabber Shift Knob w/ 6-speed logo
• Whiteline Shift Transmission Mount Bushing Insert
Driveline:
• DSS Carbon Fiber Driveshaft
• BMR Driveshaft Safety Loop
• DSS 800HP Rear Axles
IRS / Suspension:
• KW Variant 3 Coilovers
• BMR BK047 – Bushing Kit, Rear Cradle, Poly
• BMR TCA045 – Vertical Links, Rear Lower Control Arms, Delrin
• BMR BK055 – Bearing Kit, Lower Control Arm, Rear
• BMR BK049 – Bushing Kit, Differential, Polyurethane (Red)
• BMR FC003 – Camber Bolts, Front, 2.5 Degrees Offset
Exhaust:
• Bassani Catback 3” X-Cross Over & Race Muffler System
Brakes:
• StopTech Sport Rotors – Front & Rear Drilled / Slotted (Currently being Installed)
• Carbotech Pads – Front (Currently being Installed)
• Steeda Stainless Braided Brake Lines (Currently being Installed)
• DOT 4 Brake Fluid (Currently being Installed)
• Powder Coated Calipers – (Currently being Installed)
Lighting:
• Diode Dynamic “Cool White” Stage 2 Map Bulbs
• Diode Dynamic ” Cool White” Stage 2 Glove Box Bulb
• Diode Dynamic “Cool White” Stage 2 Map Light Bulbs
• Diode Dynamic XP80 Reverse Light Bulb
Wheels & Tires:
• Need4Speed Motorsports Project 6GR Satin Black 19×10 Front & 19×11 Rear Wheels
• Yokohama ADVAN NEOVA AD08 R 275x35x19 Front & 305x35x19 Rear Tires
• OEM TPMS
• Gorilla Black Lug Nuts
Paint Sealant:
• New Car Prep w/ Two-Step Paint Correction
• Modesta BC-04 Coating
• Cquartz Wheel Coating
• Clear Bra – Front Fascia, Fenders & Hood – (Scheduled to be Installed)
Visual & Misc:
• Llumar Ceramic 15% Window Tinting with Llumar Air 90 Windshield Tint
• Clear Bra Front Headlights
• TagArmur Carbon Fiber Rear License Plate Frame
• Lloyd’s “GT” Floor & Trunk Mats
• Ford Racing Hood Struts
• Whipple Carbon Fiber Jackshaft Cover
• Whipple Carbon Fiber Intake Tube
• MAK Performance ‘Supercharger” Emblem
• Trucarbon Carbon Fiber Coil Pack Covers
• Billet Custom Coil Cover Insert “5.0L Supercharged” painted Ruby Red w/ Black Lettering
• Trucarbon Ram Air Hood w/ Custom Paint Job (Out for Custom Paint Job)
• Trucarbon Front Chin Spoiler
• Trucarbon Side Skirts
• Trucarbon Rear Bumper Trim & Diffuser
• Trucarbon Upper Grille w/ Custom RaceMesh Gothic Black Chrome Mesh
• Trucarbon Lower Grille w/ Custom RaceMesh Gothic Black Chrome Mesh
• Trucarbon Performance Pack Dual Gauge Dash Kit
• Trucarbon Window Switch Covers
• Trucarbon Coin Tray
• Trucarbon Coolant Reservoir Cover
• Trucarbon Radiator Cover
• GT350R Steering Wheel
• Custom Alcantara Shift Boot, E-Brake & Monogrammed Padded Armrest Cover
