We’ve teamed up again with our friends at J&M Products for another Mustang6G Giveaway Contest!
After several years of revisions and testing J&M Products/Hotpart.com has finally released its S550 Mustang rear shock mounts.
J&M Products manufactures these performance shock mounts from high strength grade 50 steel and then fully TIG welds them. These high strength bearing mounts replace the weak cast aluminum shock mount. Unlike the factory mounts, the J&M mounts use a specially designed heat treated Chrome-Moly spherical bearing that stops the deflection caused by the soft rubber bushing. By removing the rubber, J&M mounts eliminate the deflection that gives the car a bouncy feeling when using stiffer shocks or lowering springs.
These rear mounts fit all 2015-2019 Mustangs including those equipped with MagneRide and the best part is — they come with a lifetime warranty!
Be sure to check out the Giveaway Contest and the full product details of the J&M Products 2015-19 Mustang Rear Shock Mounts in our forums.
