ZL1 Addons Jack Pads
THX 138
Brownsburg, IN
2016 GT350 Track Pack, 2002 Porsche Boxster S 3.8L
^^^ I’ve been using hockey pucks for years on hydraulic floor jacks. Also use them for woodworking projects when I need the piece off the bench. Pucks are cheap too!
+1. I can buy a heckuva lot of hockey pucks for $69.99. Two hockey pucks screwed together, with the top one cut in half and a 1/2" section removed from the middle, make for a perfectly functional jacking pad. I use it with my other car that has a pinch weld jacking location too. :cheers:
Nfs1000f
Nfs1000f
Upstate NY
Neal
2017 GT350 & 2019 Ford Fusion SEL Hybrid
Is it the pinch weld that is doing the lifting, or the horizontal flat surface above the weld?
StrongFord
SE Michigan
2015 GT Premium, MT, Deep Impact Blue, 401A
Pinch weld. It doesn't touch the floor pan.
Caballus
Over Yonder
GT350
What about jack stands? With rails you can lift and still have room for jack stands near the lift point. How do you handle that with jack pads?
StrongFord
SE Michigan
Pads don't give a much benefit to jack stand placement. I have lifted the whole side of the car using just the front pad and place a jack stand under the rear pad. Normally I still place stands under the front cradle and rear suspension mounts.
