mxdave91
- Sep 20, 2017
- johnstown, PA
- 2017 gt premium w/PP
So I installed a set of long tubes over the weekend, and I ended up with a small leak on the passenger side header. No problem, i'll just order new factory gaskets and I should be a-ok.
I also experienced a pretty good in-cab vibration throughout the rpm range, and ManBearPig, here on the forums, told me that I probably tightened the motor mount brackets up wrong (which he was right), but I re-installed the brackets today the proper way, and I still have a pretty good vibration throughout the rpm range. I checked to see if my exhaust was touching anywhere and it isn't. It's close in a few spots, but not touching.
I also started noticing today that when I close the hood with the car running, the engine slows down and even stalled one time. even if I gently lower the hood and just let it rest on the hood latch without latching it, it still bogs the motor and wants to stall. I looked under the hood with a flashlight and it's not even touching anything when this phenomenon happens. needless to say i'm just about at my wits end:frusty::frusty::frusty::frusty:
