Jmeo
You said member ;)
- May 28, 2014
- Massachusetts
- Jaime
- 2020 GT500, 2022 F150 PowerBoost
- Vehicle Showcase
- 2
Well, pulled the trigger on a Whipple kit for my PP GT! So excited!
I was originally going with Roush as my dealer said they would honor the factory power train warranty (with them installing it) but I just can't do it. I am a huge Whipple fan and had one on my 05 and have been really regretting the decision. The new system looks freaking unbelievable and in my opinion is far superior to Roush.
The straw that broke the Roush camel's (Mike Mike Mike Mike Mike) back was finding out the K brace gets destroyed for installation. I believe Roush is the only one that does this and personally I don't like it.
Tasca Mod Shop will be doing the install so that makes me happy. My father would be proud of me as he used to race Tasca back in the 60's. Tasca has a huge reputation for outstanding performance and couldn't be happier to have them do the install.
I'm told we are looking at least 4 weeks before the kit arrives as Whipple just started shipping preorders and I'm late to the list but I'm not concerned, it just gives me more time to save some money.
I will be sure to keep you guys who may be interested up to date.
Jaime
UPDATED WITH INFO FROM WHIPPLE SUPERCHARGERS (click
3.75" SC Pulley is standard which makes 10psi of boost with the stock TB or 11psi with the 132mm Crusher throttle body. A 4" pulley can be substituted and will net roughly 1.5psi less. One thing to note, this power gain is part of the kit design and all the unique features, not just boost and tuning. While some may be able to cram enough boost and timing to get to these numbers, we feel comfortable at this power level for an everyday street driver. We won't offer anything that we don't think will survive.
The stock RPM limiter will be slightly lower, 7000rpm vs 7200 as shown as that was for testing, the net loss is 1-4 hp. But this testing was done with the smaller heat exchanger (prototype), production units are netting about 5-10rw more with the larger heat exchanger that is standard with every kit. Standard HE is nearly 40% bigger.....
The K-Support clears the SC and components with no problem. No modification needed. The strut tower brace will not fit due to the SC height.
The IC reservoir is located in the driver inner fender. Accessible from the top, just below the air filter or from the wheel hose by removing a few bolts, pretty easy. We didn't put it there because there was nowhere in the engine compartment, we put it there to get more capacity and away from the engine heat. Other companies reservoirs get hot, especially if aluminum and help heat the water/coolant. While this is a small amount, we left no stone unturned.
As for the soundtube, since we did not build a 11-14 kit, we didn't know about plugging that off until last minute before sema so it wasn't done. Then couldn't get some in time.....:frusty: All have the block off at the firewall now, standard in every kit.
Hope this helps.:ford:
No problem. It technically can be done without removing fascia, but its far easier to remove. You have to remove the bottom shroud either way, the upper radiator shroud is only 8 push pins and the fascia is really easy to come off. We have them off in about 30 minutes including bottom and top. There's 2 little bolts that you have to know where they are at to get it loose, but once you know that, its very easy.
No, wheel housing (OEM calls it that) or inner fender does not get modified or removed. If you have fascia off, the IC reservoir uses 3 factory bolt holes and that holds the IC pump as well. We drill 1 hole to feed the IC feed line from HE to IC (1 1/2" hole saw) and cut about a 2" section of plastic for the inlet of the HE. No other cuts.
Yes, for CA emissions applications, we have a plastic air box (with lid) including the carbon trap. It still is open on the bottom/front for proper airflow but the top is sealed.
Currently the CAI option (all we currently have) comes in standard black. We can certainly color match it if you go with a custom color option. The MAF can be powder coated as well. Standard is black so this must be requested.
Correct, to be 50-state legal (nobody currently is), you will need the carbon trap style air system and the EO decal. The good news is that the calibration is the same so technically its interchangeable.
We have applied for EO, we expect to be done in 90-120 days.
Glad to help.
1. Yes, will still work in the different modes. I've used track here but have not tried snow, as its about 60deg here now Those settings are offsets from the base cal so they maintain.
2. SC pulley and idler system is on the forward loop, sharing the alternator and water pump. 6-rib system. No slip issues what so ever. Massive wrap on the huge pulley (remember its a big SC) and a true HD Dayco tensioner. This is an incredible belt system, we can guarantee that. We also have a 10-rib belt system coming in about 30 days (already on dyno testing) that comes with an ATI balancer, billet idlers and billet water pump pulley...
3. We do have a set of carbon coil covers that were offering. Have a few kits in stock. They are blank on the top so we've been adding some domed decals to them for some added effect.
4. No plans, we wanna see that huge grin!!:cheers:
No worries. Yes, there's an excellent story of how and why this kit came about, but not one I can put on the internet... :cheers:
The standard HE is the oversized one. We started with a smaller unit for prototype because we had in stock. Production units are now in stock and what the kits are shipping with. The dual fan bolts right on to that huge HE.
Were using the standard Bosch unit. There are better pumps but at a much higher cost. The Bosch is adequate with the proper system.
Reservoir has 3/4" hose barbs and a 1" filler neck. You would need a IC box with a fuel cell style cap to really add ice properly.
Powertrain warranty will be for all, stock tb, 90mm or 132mm.
Auto will be shipping Feb 2nd. Already doing testing on it. Cal has some trq mgt left in it for proper life.
Certainly have a good whine, I would say from memory, pretty close the 05-10.
Here's a few images.
Far easier than the Roush kit!!! Possibly half the time. Of course Dyno time and road test adds sometime but in general it's a very easy install. And of course once you do one the next is even easier.
No grinding the block, don't remove water pump, easier belt system and more componets are pre-assembled.
1 year on all the parts we supply with kit.
We're working on the extended warranty, should be very soon.
Yup, we made a trick billet adjustable idler to go in the stock location and made a beautiful billet bracket that mounts on the passenger side of engine.
Please excuse the photo, not the best.
