Which wire or Fuse ?
svfetter
Louisville, KY
2007 427r - 2015 stage 2
Putting a Kicker Hideaway Sub in my 2015 Premium (9) speaker setup. I am aware that this sub has an auto on / off feature. Typical installation recommends pulling power directly from the battery. I would prefer to tie into a 12v line in or around the kick panel fuse area that becomes hot when the ignition is turned on. Can anyone recommend a wire or which fuse to tap to accomplish this. Thanks.
mumbles
ATL
Eric
'16 GT Prem OW
The line you are referring to would only be used as a remote turn on for the subs amplifier, not to power the amp. You would still need to run a power wire (4 gauge) from the battery to the amp.
Fuse 23 seems to be what most have used for the remote turn on.
