Wheel spacers
Hit Redline
SoCal
On the Hunt
Upgraded wheels so no longer need these spacers. They are all 20mm and hub centric. Used with PP wheels and was perfect.
Looking $75 shipped to lower 48
luv2spedup
Houston
2016 Race Red GT (Roush Phase 1)
do you have any pics of your car with the spacer? would like to see how it sat
Hit Redline
SoCal
On the Hunt
Hope these help. I was on Swift Springs as well.
Ryan P
NE Ohio
Jap Crap
Do you have to shorten the factory lugs to use these?
MaskedRacerX
Driver
Vilano Beach, FL
DT
'21_JWS4XE / '21_TM3P
Definitely, the 23mm spacers are the thinnest that don't need any stud modification - and even those, depending on exact tolerances of your car, can result in PP wheels making a very tiny amount of contact in the "pockets".
I'd assume that being the case, 20mm spacers would need 3-4mm of trimming on the factory studs.
Hit Redline
SoCal
On the Hunt
Yes as stated above. Not sure how much as I had a tire shop do it. Not sure if this applies only to the PP wheels or not.
Plenty of stud left for new wheels with proper offset if that is a concern
