TheLion
If the radiator has enough reserve capacity then you should expect to see a temperature drop if about 18F on average.The Ford diagram isn't showing up.
Also, with the stock thermostat of 178°, I'm sitting right at 180° give or take a few degrees based on ambient temp and load. I was wondering if I could expect to stay around 160° with your thermostat. I didn't compare with TheLion because he has a non-PP car whereas I have a PP car. I've seen non-PP car owners say they stay around 190°-200° whereas, again, I stay right on the rated thermostat temperature.
If your PP radiator does not have enough reserve capacity to regulate coolant temp down, then you would not expect to see the expect drop in temperature.
All heat exchangers have a thermal maximum limit. At maximum thermal load of the heat exchanger, the thermostat should be fully open, or possibly just before maxim depending on how the spring rates are set and their linearity.
From what your describing, the factory thermostat is not fully open, indicating there is still reserve capacity. From all of my experiences, fully open or near fully open results in a coolant temp about 15 to 20F above the thermostat starting point. So if you have a 180F thermostat, worst case coolant temps would typically be around 195F to 200F.
Lower temperatures indicate lighter load conditions where the thermostat is not fully open. Spring rates are not 100% linear in real life, so there's a bit of curve to the temp vs. flow rate...
