What are the normal readings on EB for:
Oil pressure (stone cold before warm up)
Oil pressure (normal after warm up)
Cylinder head temp (normal op temps)
Just picked up a new 2016 Premium EB w/ Performance Package, so it has the center gauges in dash between air vents.
I was visually monitoring things while driving and am curious to know the above specs - appreciate it in advance!!
TheWildman
Jazz Master
Columbia
Michael
2018 Kona EcoBoost Base (PP)
I usually see my oil pressure around 80 when cold.
When warmed up, it should be around 20
Normal operating temps for the cylinder head are I'd say between 180 and 195 degrees. It may jump up to over 200 here and there, but don't let that scare you. Perfectly normal.
Local
Long Beach, CA
TBD
My 2016 pp eb maintains a cylinder head temp between about 198-215. This has been the case since purchase about 3 weeks ago. Mostly stop and go traffic in socal winter weather (50-65 degrees).
stevnoof
new jersey
2016 mustang gt base manual 3.31
cylinder head 180F under most circumstances.
TheNameAndy
Las Vegas
2015 Ecoboost PP
what about your guys Air/Fuel ratio?
at a stand still mine is 13-14.1 .. when I give it some gas it is 12-14.5, is this normal?
stevnoof
new jersey
read 14.0 at idle. on the accessport it read 14.75 so who knows. I should check it out at WOT probably reads like 11.0
guitrflip
Glendale (818)
Jason
2017 Mustang GT Premium
That's completely normal [MENTION=15131]TheNameAndy[/MENTION]. We live in SoCal, usually it would be 12-20 (If you let go of the gas), but the weather has become cooler so 12-14.5 is what mine is reading as well.
TheNameAndy
Las Vegas
2015 Ecoboost PP
Thank you
