Two Minute Tuesday - Supercharger Pulleys
JakeLethal
Wellington, FL
Jake
2022 F-150 RCSB 5.0
Regardless of the supercharger system you pick for your ride, whether it be a Centrifugal or Root-Style unit, it’s got to have a pulley to spin the rotors/turbine inside the head unit to make boost. The pulley is what makes the whole system function, allowing as much boost as you want, depending on the size of the pulley. Of course, all pulleys are NOT equal. With some like Griptec’s that help promote better grip on the serpentine belt to limit belt slip under high boost conditions, a common issue on many supercharger kits.
Check out everything on Supercharger Pulleys here!
Griptec Pulley Guide : https://www.lethalperformance.com/griptec-guide
SPE Pulleys https://www.lethalperformance.com/spe/supercharger-pulleys
Whipple Pulley Chart : https://www.lethalperformance.com/whipple-pulley-chart
