info@trinityautosport
- Feb 3, 2016
- Anaheim, CA
- 2015 Mustang
Ford Mustang GT 5.0 Engine Cover
These parts are exotic-looking, race-inspired, and are unmatched in quality.
Features:
- Pre-preg. Carbon Fiber Manufacturing Process
Engine Covers are vacuum-bagged and cured in the autoclave at high temperatures, ensuring quality, durability, and extremely-high strengh-to-weight ratios. - Fade-Resistant Clear Coat
Engine Covers are finished with UV-stable, production clear coat paint, then individually hand-polished to a brilliant shine. - Easy Installation
Engine Covers are designed to factory specifications for easy installation and clean fit and finish.
Ford Mustang GT 5.0 Radiator Cooling Plate
The flow of air is not only limited to the outside of a car. To maximize cooling capabilities, a radiator needs a direct flow of air to allow an engine to maintain consistent temperatures on the race track. Because of structural gaps above the radiator, the flow of air could escape making the radiator not as efficient as it could be. To help improve the flow of air into the radiator, APR Carbon Fiber Radiator Cooling Plates can be utilized to channel the flow of air directly to the radiator. This will improve the efficiency of the radiator while adding a high-tech, race inspired look to your engine bay.
Features:
The APR Radiator Cooling Plates are constructed by high temperature and high pressure pre-preg. carbon fiber production process, making them durable and able to withstand elevated engine bay temperatures. - Designed for Easy Installation
The APR Radiator Cooling Plates are designed to factory specifications for easy installation and clean fit and finish. - Fade Resistant Epoxy Coating
To ensure durability, the APR Radiator Cooling Plate uses fade resistant epoxy coating to reduce the effects of high engine bay temperatures.
