Stripped Screw Head - belly pan
aham23
FPC 5.2
Phoenix
22 FJG Mach 1 w/ HP
2019 GT PP1. Had all but one of the screw bolts and push pins removed and the last one has a rounded head. The last one! Need to pull the belly pan to get at the HE up front on the pass side.
How do I get it out?
wade001
Central Florida
Wade
2019 GT Prem. 10r80, PP1, 401A, Active Exhaust
can you cut a groove/slit into the head and use a screw driver to get it out? only thing i can think of, or vice grips if you can get them to lock onto the nut head.
short of failing that. i guess the next step is a screw extractor, which is probably going to be a huge PITA
