Adaraas
- Feb 13, 2015
- Central FL
- Austin
- 16 Premium GT, 17 Laramie Cummins
Stage 2 D1SC, currently on a 4" Pulley with a wastegate. I believe I have a 4.5" Pulley and a 4.75" Pulley somewhere but not sure. Oil changed every 3k Miles, currently has 9k miles on it. Has Coastal Dyno Hard inlet tube. Big red BOV
ID1K Injectors. JMS PNP BAP
Coastal Dyno Wastegate tube with Tial MVR wastegate. I've got all 7 wastegate springs so you can run whatever psi you want. My car at 10lbs made over 670, but it wasnt a complete pull so still had some to go.
Alkycontrol dual nozzle methanol kit. Currently have a 10gph nozzle and a 15gph nozzle, but you can purchase additional nozzles for like 7 Dollars if running a lower boost number. I've ran the car at 18lbs on pump gas with this setup with zero knock using 100% methanol. I will include my washer fluid bottle as thats the reservior.
Asking 7k, but make me a reasonable offer. I'm located in Brooksville area, and will drive up to two hours to deliver it. Can also ship on your dime.
Kit is currently still on the car, but I will start taking it off as soon as I get some interest. Thanks
