Smoked my rear pads @ 25k miles!!
Dspec_S550
Los Angeles
2015 Oxford White Mustang Ecoboost
So my rear pads are already spent.
Fronts are at like 50%. Seems as if I am using the traction control/stability management a bit too much! ;)
I was'nt expecting this, so next time you have your rear wheels off, check the brake pad life. :cheers:
VinnAY
Kansas City
18 Camaro 1SS/1LE
That is really short for rear pads, they normally last twice the fronts.
Dspec_S550
Dspec_S550
Los Angeles
I know, right?
Dspec_S550
Dspec_S550
Los Angeles
I just swapped out the brakes in the rear, and only the outer pad wore, the inner pad was about 50% worn...
I guess I will need to lube the pins? Im not sure what else would cause that.
jasonstang
Omaha, NE
2017 GB GT/CS 6MT
dragging hand brake?
Dspec_S550
Dspec_S550
Los Angeles
its been super loose since it left the factory, and barely works. I dont use it often.
Xavier
NH
2016 GT
I'm pretty sure I'm gonna end up doing the same thing. The AdvanceTrac system can really eat up the rear brakes if you're the type who likes to drive spiritedly and doesn't remember to turn it off every time. Whoops.
Dspec_S550
Dspec_S550
Los Angeles
no mechanical issues I can tell, this failure looks like stick pins, and a caliper that was constantly dragging the outer pad. The inner pad did have some uneven (tapered) wear, but I cant chock it up to anything other than isolated to the caliper/pins...
wildcatgoal
@sirboom_photography
TBD
After 20K my rear pads barely looked bothered compared to the fronts.
