Shaker stock help need info
Hammerzin
Scott
2015 Mustang gt
Hey what I've done is installed a t harness at the back of the stock head unit and I wanting to run an amp to power the doors and front tweets and maybe rear decks what amp should I use to do this have seperate amps for subs
MathematicsDP
Middleburg, Florida
Darryl
2017 Ford Mustang GT
Are you planning on replacing the factory door speakers with aftermarket speakers? Also are you planning on going fully active with your setup (each speaker has its own separate channel)?
MathematicsDP
Middleburg, Florida
Darryl
Great! This is exactly how I have mine set up. I have two 4 channel amplifiers and one dedicated amplifier for my subwoofers.
It's totally up to you on what amplifier you choose to go with. I'm not big on naming brands because everyone has their own taste and budget as well. But my personal opinion is go with an amplifier that is truly rated for the power at RMS no matter what brand you choose. I'm big at looking at test on YouTube and basing my decision on that.
If you're looking for some really good compact amps that deliver what they promise, you can look into amps like the Rockford Fosgate T400X4ad which is a 4 channel amp that I have powering my two front tweeters and two front 2 inch mid speakers, they're excellent compact amps.
I have the following setup:
Front Stage Speakers:
Infinity Kappa 60CSX – 6.5" 2‑way component set (midbass + tweeters)
Infinity Kappa 20MX – 2" midrange drivers
Rear Speakers:
Infinity Kappa 62IX – 6.5" coaxials
Subwoofers:
2 JL Audio 13TW5 Shallow‑mount subs
Amplifiers
Rockford Fosgate T400X4ad – 4‑channel amplifier (Tweeters and Mids)
Rockford Fosgate T600‑4 – 4‑channel amplifier
(Front door MidBass Subs and Rear deck Speakers)
Rockford Fosgate T1500‑1bdCP – mono amplifier
(Subwoofers)
Processor:
Rockford Fosgate DSR1 DSP
iDatalink HRN‑AR‑FO3 integration harness
Power:
0‑gauge OFC power wire
4‑gauge power wire (distribution block to amplifiers)
Odyssey ODP‑AMG96R AGM battery (Main Battery)
XS Power XP950 (Reserve Battery)
JS 320 Amp Alternator
Big 3 upgrade with 0 Gauge OFC wire
