NorthernMuscle
Hey Guys,
I'm trying to order new upper rear shock mounts, in order to get more bump travel than my current Steeda billet mounts allow for.
Vorshlag (who seems like my best option) needs a few measurements to guarantee fitment, as they've never made adapter spools for these exact shocks.
They need the dimension of the part of the shaft that goes into the upper mount (which I believe is 12mm wide?), as well as the length of the threaded part, as well as any other info that would be pertinent to fitting the shaft to the mount.
These are the exact shocks I have https://www.steeda.com/rear-shocks-15-17-adjustable.html
I have matching Steeda's up front, along with a handful of other Steeda bits...
For me to get this info I'd need to pull the wheel, then the upper mount, then detach the shock, put it all back, and repeat when the new mounts arrived... Do any of you have one accessible to measure, or have a spec sheet of some kind that specifies these dimensions?
@SteedaTech
@SteedaTech
