amhauke
Long story short I relocated my widebands from the manifolds to the Hellion xpipe after the turbos. I was able to separate the drivers side harness enough to reach. On the passenger side I extended the harness with 18ga wire and some weather tight seal crimp connectors and now I get a P0133, "02 sensor circuit slow response bank 1 sensor 1" code and the car is missing and has a loss of power. Occasionally as I drive I can feel the miss go away and the car clears right up. Comes and goes intermediate. I switched injectors at the same time and have a base tune so I don't know if this will go away when the car is tuned or if I should fix this before.
Any thoughts before I investigate?
Thanks
Thanks
