Recomendation on size
timd38
Hudson WI
GT/CS C6 Corvette
I want to run 19" wheels and I want 4 of the same size so I can rotate them.
Does anyone know what the widest wheel and largest tire I can run and use the same on all four corners? Also what offset? The car is a DD with 1.5" front and 1" rear drop.
Thanks!
kroy11
Kentucky
Kelby
2015 Race Red Manual GT
I think most are going with 285/35/19 or 275/40/19 if your going square setup. And the drop should still be fine with these from what I understand. And the best wheel width for these is a 19/9.5
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
It depends on the wheels your after, each wheel has different offsets, but for instance
285/35/19 and a 19x10 ET 35-40
For instance
MRR M350 19x10 ET 40 with 285/35/19 tires all around.
timd38
timd38
Hudson WI
GT/CS C6 Corvette
For instance
Thanks! I will contact you when the OE tires wear out!
Need4SpeedMotors
Los Angeles, CA
www.n4sm.com
N4SM Team
