QuickJacks on sale boys!!!
Alain
Northern NJ
Alain
2016 Challenger Hellcat / 2019 350R #413
https://www.ecstuning.com/News/Quic...mpaign=Catch_All_QuickJack_04282020_EP_MKT423
when I bought my 7,000 lbs extended QuickJacks over a year ago I payed more than they are asking for at ECS.
they are worth the price if you can afford them. I’ve had my R on my QuickJacks already and it’s easy peasey. I had to drive the front wheels up on a wooden plank to get clearance in the front. Other than that, it’s a breeze to get all 4 wheels off the ground.
Deleted member 37397
Guest
Got mine for $800 last fall at Costco. They are the 5000 lb and have all the new hardware connectors so it’s not like they were getting rid of old stock
ronaldwalter
Long Beach CA
2018 Shelby
What is the max height you can lift with this? Which model did you get?
Alain
Alain
Northern NJ
Alain
I got the 7,000 pound extended version.
I couldn’t tell you off the top of my head exactly how high it goes but I’ll tell you that there’s nothing you’ll ever need to do under the car that you wouldn’t be able to do with this lift.
I am uploading some pictures of me using it on my cars a month ago. Hopefully you’ll be able to tell if the height satisfies your needs by looking at the pictures.
I’m sure you could go on their website and find the actual height.
NoXiDe
GA
GT350
Do you need a separate air compressor unit or is the 110 Volts Power Unit from QuickJacks and a possible an extension cord all you need?
Guest
Comes with everything you need, hydraulic hoses are fairly long. I don’t need an extension cord, depends what your garage setup is I suppose
Alain
Alain
Northern NJ
Alain
You don’t need anything. Plug it into the wall and you’re good to go. They offer a variety of power units which run on different volt levels.
I got the one which runs on a regular wall outlet.
DonnieO
Donnie
2017 mustang gt cs
Think you can install a set of headers on these?
Alain
Alain
Northern NJ
Alain
I don’t see why not, plenty of room to slide the headers in from underneath.
FreddyG
Planet Earth
4 wheels and a seat
Here are the specs off of the Quickjack website:
Lifting capacity
7,000 lbs. (3,175 kg)
Lowered height
A - Frame only: 3.5" (89 mm)
B - With 2" block: 3.75" (95 mm)
Lifting height
C - Frame only: 18" (457 mm)
D - With 2" block: 18.25" (464 mm)
E - With 3" block: 19.25" (489 mm)
F - Max. height: 21.25" (540 mm)
G - With adapters: 21.25" (540 mm)
H - With adapters + pin: 24" (610 mm)
Compare All Specifications
Lift point spread
I - Maximum: 60" (1,524 mm)
J - Minimum: 31.5" (800 mm)
Frame dimensions (ea.)
K - Width: 12.5" (318 mm)
L - Length: 70" (1,778 mm)
A - Height: 3.5" (89 mm)
Weight: 96 lbs. (44 kg)
Other specs
Time to full rise: 30 seconds
Power unit weight: 15 lbs. (7 kg)
Total shipping weight: 242 lbs. (110 kg)
