Question about power wire to battery
ib2loud
Oklahoma
Brad
2015 Ecoboost
Currently I have my amp's power wire on the small bolt that holds the battery terminal down. I noticed some nice beefy terminals on the box by the battery but wasn't sure if it would hurt or help anything to go there instead. Seems like the terminal on the battery has some coating or just isn't making a real nice solid connection.
Thanks for any help.
ForTehNguyen
Houston, Texas
15 GT
closer to the battery is better. If you use the 3 large terminals on the fuse/relay box, depending on what youre running on the amp you are putting a heavier load on that circuit. Whereas if you went directly off the battery you dont run into this issue. Im running my amp on the battery terminal bolt with no issues.
