blusdacolor
- Nov 7, 2016
- Leawood KS
- Competition Orange 6 speed GT
I purchased a MSD 2 step for my 15 Gt, its a pretty straight forward hard to mess up install. ( Remove coils, plug the MSD coils in- wire to ground and clutch) All plug and play. So I installed everything and tested out the 2 step after I got it hooked up, it engaged properly. Took it for a test drive and my car ran like garbage, got multiple misfires.
So I took off my cai, flashed ecu to stock and it ran fine. Installed the cai- retuned to 93, still runs fine. I then put on the 2 Step thinking it was a fluke- misfires terribly. I would appreciate any help! My thoughts are that the box itself is fine- there is an issue with the coil plug or wiring.
Im Bama tuned, long tubes, comp cams, MAK performace cat delete, and a CAI.
Set at 4k RPM (Before I test drove I did 3-4-5k RPM tests)
