Question about Longtube Headers lead pipes
Varekai
Mustang Enthusiast
Hernando County, FL
2018 Ecoboost
I was thinking about getting Longtube Headers a bit early, and was looking for something on the cheaper side. Question is this, I saw on Beefcakes site that they have the Stainless Works LT without leads for $595. I have the Lethal H pipe bottleneck eliminators. Would I be able to connect those straight to the headers to save a few hundred bucks?
Youngmustang
Chicago
2015 Mustang Gt DIB
No you need the lead pipes I thought of that.
http://www.mustang6g.com/forums/showthread.php?t=28702
Edit: Nevermind. I posted without actually reading the post. The h-pipe 2.5" and I think the end of the collectors is 3". You'll have to get a small piece of pipe That necks down to 2.5" to fit the h-pipe. I would say it will work
Varekai
Varekai
Mustang Enthusiast
Hernando County, FL
2018 Ecoboost
rio16
MAD_50HH
Bay Area SJ, CA
Rio
2015 Mustang GT Whippled Competition Orange
better to get the whole headers..same piping..no headaches later on...get SW and wait for the holiday discount..im sure they'll be another one
Derek@Lethal
Wellington, FL
Derek
2012 Mustang GT 300A w/ Brembo's
OP, since you have the bottle neck eliminator resonator delete, you will not only need the matching lead pipes for whatever brand header you choose, but you may also need to modify those lead pipes if they have the stock 2-1/4" outlet for OEM connect. The bottle neck eliminator gets rid of that 2-1/4" section, hence it's name, so it won't connect to a lead pipe with the OEM sized connection. Unless the lead pipe is available with the 2-1/2" outlet, it will not be a bolt on affair. Your other option is just to purchase our regular resonator delete which does have the OEM connection and that will bolt to any long tube header kit that will connect to the OEM resonator.
Hope that clears some things up, let us know if you have any other questions.
Thanks.
beefcake
Bethel
2018 Ford Mustang
we have some killer deals on the full stainless power system, if your in need
let me know
Varekai
Varekai
Mustang Enthusiast
Hernando County, FL
2018 Ecoboost
So basically because I'm on stock exhaust it's going to bottleneck regardless? In that case would I even gain any benefits without also going with a 3 inch aftermarket exhaust?
beefcake
Bethel
2018 Ford Mustang
n/a won't change power on a 3" setup
Derek@Lethal
Wellington, FL
Derek
On a basically stock car, you won't see much difference at all between the stock "bottle neck" or a full 3" system. If you had a blower on the car, then I'd recommend going with a full 3" system for sure. When you really start moving air, with a power adder or RPM, the bigger exhaust will really help.
Let us know if you have any other questions about exhaust.
beefcake
Bethel
2018 Ford Mustang
So basically from a performance standpoint it's useless for new to get headers?
no, headers are great, what i mean is if your worried about the factory connection point, n/a , shouldn't make a difference.
and down the road if you go power adder, it's as simple as adding in a little 3" section of pipe to take away the neckdown
Varekai
Varekai
Mustang Enthusiast
Hernando County, FL
2018 Ecoboost
Sent you a pm
Derek@Lethal
Wellington, FL
Derek
We now have factory connect pipes avail from ARH, same 5.0 ARHeaders, NEW factory connect pipes.
This would be the way to go, OP!!! Give us a call about the ARH headers if you have any questions. :thumbsup:
Varekai
Varekai
Mustang Enthusiast
Hernando County, FL
2018 Ecoboost
Sounds sweet. Going to think about it for a bit, my fiance just got bad news about her work so I have to keep my finances low for a little. Thanks all.
