marylandspeed
- Jul 6, 2015
- Southern MD
- Mustang
With the Quick Time Electric Cutout you can have the best of both worlds! Quiet for the street and wide open for the strip. Go from stealth quiet to wide open power and experience the gains even if your already enjoying an aftermarket exhaust system. You control the volume, you control the power. Open your exhaust with the flip of a switch. Run it closed, run it all the way open or any position in between. Adjust your back pressure to save gas.
CNC 6061 Aircraft Aluminum Body
Stainless Steel Butterfly Plate & Shaft
6061 Aircraft Aluminum Motor Plate
High Torque DC Gear Driven Motor
Gears Made from High Temp Steel for Long Life
2 position Momentary Toggle Switch
Weather proof wiring harnesses
Weather tight Connectors for Superior Sealing
Made in the USA
Add recommended turn downs and wireless remote control for the ultimate low profile cutout!
Made in the USA
