DarkSubRosa
GTFO_0027
- Dec 9, 2013
- Nolensville, TN
- 2015 Mustang GT / 2015 Porsche GT3
Wheels/Tires
Vossen VPS-301 20x10 +30, 20x11 +48
Hankook Ventus RS3 285/35/20 & 305/35/20
Monster lugs
Suspension
Maximum Motorsports Camber Plates
Steeda Ultralite Springs
Steeda Subframe alignment kit - replaced by solid FRPP Bushings
Steeda Adjustable Toe Links
Steeda Front and Rear Sway Bars w/ Billet Mounts
Steeda G-Trak
Steeda Jacking Rails
Steeda IRS Bushing Support System - replaced by solid FRPP Bushings
Steeda Diff Bushing Inserts - replaced by solid FRPP Bushings
Steeda Adjustable Shocks
Steeda Billet rear shock mounts
Steeda Bumpstops
Steeda IRS Subframe Support Braces
Steeda Vertical Links
Steeda Rear Adjustable Upper Camber Arms
Steeda S550 Mustang Adjustable Swaybar Endlinks (front and rear set)
Steeda S550 Mustang Rear Lower Control Arm Spherical Bearings
Steeda Knuckle To Toe Link Bearing Assembly
Steeda Front Tension Links w/ Bearings
Steeda Bumpsteer kit
Steeda Front Control Arms w/ Bearings
Ford Performance Solid IRS Bushings
Ford Performance Solid Diff Bushings
Ford Performance S550 Mustang Rear Wheel Hub Kit w/ 3" ARP Studs
Ford Performance S550 Mustang Front Wheel Hub Kit w/ 3" ARP Studs
Performance
Whipple Gen 3 w/ 150mm TB
Corsa Sport Catback
Corsa Catless Headers
ARP Header Bolts
Reisch 170 degree thermostat
nGauge/Lund FF Tune
Watson Catch Can
Watson Battery Relocation
MGW TR6060 Conversion Shifter
Steeda Tri-Ax - Had on my MT82
Steeda Delrin Reverse Lockout Collar
Steeda Transmission bushing insert
Steeda Clutch Assist Spring
DSS Carbon Fiber Driveshaft
McLeod RXT
McLeod Lightened Steel Flywheel
ARP Flywheel Bolts
Fore Fuel System - CJ Motorsports
C&R Racing Engine Coolant Reservoir
Motor Work
"Stage 2" 2007-2010 Ford Mustang GT-500 Tremec TR-6060 6 Speed Transmission. Transmission capable of supporting 1000+HP.
Transmission features
Exterior
UPR Gloss Black badging
Diode Dynamics Full LED Exterior Lighting w/ Switchbacks
SunTek Tint
Raxiom Tail light Sequencer
CDC Roof Spoiler
BigWorm Lens Tint
Zombie's Orange Puddle Lights
Diode Dynamics RGBWA Gills w/ Gloss Black shroud
Ford Racing Performance Rear Panel
RTR Upper and Lower Grills
RTR Grill Lights
RTR Side skirt extensions
RTR Rear Diffuser
Ford Performance OEM GT350 Track Pack Spoiler
Steeda Front Splitter
Cortex Carbon Fiber Hood - Sold
Quiklatch Hood Latches - Paint matched
Trackspec GT4 hood vent kit for stock hood
Interior
Diode Dynamics Full LED Interior Lighting
WeatherTech Mats
Anarchy Motive Shift Knob
GT350R Steering wheel
JPM Coachworks Door panel inserts
JPM Coachworks Knee Pads
JPM Coachworks Shift boot
JPM Coachworks Console Cover
JPM Coachworks Handbrake boot
MMD Flip Up Start button Cover
GT350R Rear Seat Delete
Watson 4 Point Cage
_______
When I first went to the dealer 6 hours away to pick her up
Foam Cannon Bath Time
Finally she's clean!
Black Pony and Carbon Fiber Background I made
Time for some modding...UPR Catch Can
UPR Gloss Black Badging
Cleaned up after emblem install + Corsa Exhaust
My Vossen VPS-301's awaiting color
and why it's called project copperhead
Monster lugs
Suspension
Steeda G-Trak
Steeda Bumpstops
Performance
Corsa Sport Catback
ARP Header Bolts
nGauge/Lund FF Tune
Watson Catch Can
McLeod RXT
ARP Flywheel Bolts
Motor Work
- 5.2L Short Block above plus New 2015+ Stage 3 Ported heads
- ARP Head Studs
- 5.2L Ford Racing Head Gaskets
- MMR/Livernois Timing Chain Guides/Arms
- New Ford Timing Components/Cam's
- New Ford Oil Pump and Pick Up
- New Ford Racing 5.0L Cross Plane Crank
- Manley Platinum Series Pistons 11 to 1 CR
- Manley H-Beam Rods with ARP2000 Rod Bolts
- Cryogenically Treated - - Total Seal Stainless Rings
- Clevite Coated Main and Rod Bearings
- ARP Main Studs and Side Bolts
- Fully Balanced and professionally assembled
- TSS Oil Pump Gears and Timing Sprocket
- Stage 2 Comp Cams S/C cams
- Manley Valve Springs and Comp Cams Retainers
- Gen 3 Stage 2 Whipple w/ Monster Heat Exchanger / 10 Rib
- Custom brushed and copper powder coated housing
- ID1700 Injectors
- Integral Bellhousing
- 26 Spline Input Shaft
- 2.97 1st Gear Ratio, .80 5th Gear Ratio, .62 6th Gear Ratio, and Bolt On Flange Design Output Shaft.
- Cryo Treated 1st thru 6th Gears, Synchronizer Sliders, Hubs, and Shift Forks
- REM Polished 1st thru 6th Gears, Synchronizer Sliders, Hubs, and Shift Forks
- Upgraded Brass Shift Fork Pads on 1st thru 4th Shift Forks
- Upgraded Carbon/Sintered Bronze Rings on 1st & Rev. Gear
- Sintered Bronze Rings used on 2nd thru 6th Gears
Exterior
SunTek Tint
CDC Roof Spoiler
BigWorm Lens Tint
RTR Grill Lights
RTR Rear Diffuser
Interior
WeatherTech Mats
Watson 4 Point Cage
_______
