Oil Separator - Driver's side
JohnBoyNC
Indian Trail, NC
2015 GT PP
Who has installed both? How much are you seeing in the driver's side compared to the passenger's side?
Overkill or a needed add-on?
TIA
Gibbo205
UK
UK 2015 Mustang & BMW E46 M3
TIA
I've done both! Mainly due to the breather hose not fitting after GT 350 setup and it was not so willing to be re-heated and bent into a new shape. So was mainly done for neatness.
Won't be trying to empty it for a few months but it is believe that the LHD bank does see less windage than RHD bank.
Lund and JDM did both say the separators do help to run more timing, marginal as they stop the fuel from seeing any dilution from oil windage and my car has seen 32 degrees timing under WOT with no knock which is pretty much E85 levels within reason on regular pump gas.
