- Apr 4, 2022
- Saint Charles, Missouri
- Website
- formlights.com
- Jordan
- 2015+ Mustangs
Looking to upgrade the styling of your Build? Look no further. Introducing LED Accent Lights from Form Lighting. If you are looking to add a modern appearance to your vehicle, installing our new accent lighting is one of the easiest things you can do to make a big impact.
Upgraded Styling. These Form Lighting Accent Lights illuminate your vehicle in a way like never before adding LED lighting to your factory accent light locations. With these premium OE-grade replacements, you’ll stand out from the crowd with an extremely modern look.
OEM-Grade Construction. All Form Lighting products are built with quality in mind and constructed using OEM-grade materials, including UV-coated polycarbonate lenses, automotive-grade LEDs and optics, and direct-fit connectors. Unlike other options on the market, each lamp features transient protection which prevents voltage spikes on the circuit board, ensuring long-term reliability. While they may not be the cheapest option on the market, the fit and finish of our lamps are superior to other aftermarket units.
Plug and Play. Our LED Accent Lights are completely plug-and play and will fit perfectly, without any body gaps. Simply take the factory housing out and reinstall. They were designed to plug into your factory connector, with no additional wiring needed. That means no dash errors, flickering, or hyperflashing.
Two-Year Warranty. All Form Lighting products are rigorously tested for reliability, and backed by a two-year warranty. The warranty is supported directly by Form Lighting, and any replacement parts, if needed, are shipped quickly from Form Lighting’s US warehouse. On the rare occasion that you may need to utilize your warranty, we try to keep the process as simple as possible - for example, no return is normally necessary.
Do you have additional questions? We’ll be happy to help!
• Reply to this thread
• Send us a direct message
• Email: [email protected]
Are you a US forum member? DM us for a FREE shipping code!
Logan Z.
Form Lighting
Logan Z.
Form Lighting
